Xmenfreak2 Neutral Newbie July 2, 2009 Share July 2, 2009 Hi bros, I am trying to downgrade windows vista to xp but not able to reformat it.. any kind souls to guide me to this? plsss.. thanks.. ↡ Advertisement Link to post Share on other sites More sharing options...
Zniper 2nd Gear July 2, 2009 Share July 2, 2009 bro, u need a bootable xp cd to do tis... it's the simplest way to do so... u cant juz right click c: and click on the format... Link to post Share on other sites More sharing options...
Reuters Clutched July 2, 2009 Share July 2, 2009 what version of vista are you using? did u check if your laptop/PC is downgradeable to XP? Link to post Share on other sites More sharing options...
Soleution Neutral Newbie July 2, 2009 Share July 2, 2009 Your hdd is on SATA, XP do not have driver for SATA so cannot format, you need to get the SATA driver for your HDD. Link to post Share on other sites More sharing options...
Happily1986 5th Gear July 3, 2009 Share July 3, 2009 Vista is more resource hungry than XP so whatever that is certified Vista compliant will certainly work on XP. Whether the machine will fly is another matter. You dont need third party SATA drivers during the installation of XP unless you are doing RAID. Then in which case you will have to install the third party drivers when Windows prompt you to do so. SATA and IDE drivers have native support in XP (be it 32bit or 64 bit). Let me just throw in the simple steps here for you. Insert your XP CD-ROM then restart the computer. Upon rebooting, hit the F8 key till a menu comes up. Select the CD-ROM drive. This will tell the computer to bootup using the bootup image in the XP CD-ROM. Windows XP setup will prompt you that there is an pre-existing installation but it probably won't recognise it since it isn't XP. Select the option to install on the partition containing the Vista OS. The idea is to get Windows to clean format and then install fresh. I recommend you do a proper format rather than a quick format. Follow the subsequent instructions on the screen. Link to post Share on other sites More sharing options...
BoneStock 5th Gear July 3, 2009 Share July 3, 2009 (edited) Hi bros, I am trying to downgrade windows vista to xp but not able to reformat it.. any kind souls to guide me to this? plsss.. thanks.. One more consideration before you install XP is to make sure that all the hw drivers are available in XP. Especially for newer computers, the drivers for XP are not available anymore in the manufacturer's site. You might be able to download the drivers from the oem sites though. Edited July 3, 2009 by BoneStock ↡ Advertisement Link to post Share on other sites More sharing options...
Need Advice on Self Storage
MyResponder app to call SCDF
Help with STA report remarks
