Tubecreamer Neutral Newbie July 21, 2009 Share July 21, 2009 Any bros on Falken ZIEX ZE912? Thot of changing to these set of wheels. I am using Eagle F1 GS-D3 now. will falken ones be much quieter comparatively? ↡ Advertisement Link to post Share on other sites More sharing options...
Ronnchee Clutched July 21, 2009 Share July 21, 2009 1st year - good 2nd year - noisy 3rd year - change tyre In short, you pay peanut, you get monkey Link to post Share on other sites More sharing options...
Emils 2nd Gear July 21, 2009 Share July 21, 2009 I'm using ZE912. Grip in dry and wet condition is decent but road noise can become rather intrusive like what Ronnchee has highlighted. Link to post Share on other sites More sharing options...
Tubecreamer Neutral Newbie July 21, 2009 Author Share July 21, 2009 (edited) wah piangz... Can recommend me slightly better ones that is good noise, ok for grip and handling? I mean I dun do high speed turning often nor speed in rain.. Edited July 21, 2009 by Tubecreamer Link to post Share on other sites More sharing options...
Ronnchee Clutched July 21, 2009 Share July 21, 2009 All depends on your budget, and how deep your pocket. Link to post Share on other sites More sharing options...
Zafira18 1st Gear July 21, 2009 Share July 21, 2009 depends on usage i think....cos for me, i'm running 40k per year , so each change only last me max 15mths.....by then the rubber still soft and i'm a happy user of falken 912 compare with previous GR80 and Mich MXV8 which are 30% more expensive... Link to post Share on other sites More sharing options...
Melvinnn Neutral Newbie July 21, 2009 Share July 21, 2009 am on falken 912.. road noise not much of a factor for me cause i usually drive alone. my speakers and bass keeps me moving so can't hear much of the outside.. Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie July 21, 2009 Share July 21, 2009 I also on Falken ZIEX ZE912. Got the made in Thailand ones from Soh Bro at $65ea (195/50/15).. I am a happy user of it. Decent Grip and cornering.. but the weakness is the noisy... can be noisy at times.. but turning up the volume will soft the problems... I would say it is value for money rather than pay peanuts get monkeys.. Link to post Share on other sites More sharing options...
Enduro25 Clutched July 23, 2009 Share July 23, 2009 so when did u change it?65/pc is a gd price... Link to post Share on other sites More sharing options...
Eagleram Neutral Newbie July 29, 2009 Share July 29, 2009 Hi bro's anyone knows wats the PSI for the falken 16 inch (205/45/16) tires? Thanks.. Link to post Share on other sites More sharing options...
Cypher 4th Gear July 29, 2009 Share July 29, 2009 Hi bro's anyone knows wats the PSI for the falken 16 inch (205/45/16) tires? Thanks.. 10% - 20% below the max PSI found at the sidewall. Used to pumped 36 PSI on my 15". Link to post Share on other sites More sharing options...
Eagleram Neutral Newbie July 29, 2009 Share July 29, 2009 icic.. thnks bro.. tht means it stated dont exceed beyond 40 PSI.... but the max stated was 50 PSI... so i got confused...:) Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie July 29, 2009 Share July 29, 2009 Change it Feb this year at Soh Bro... Price there is v competitive... Link to post Share on other sites More sharing options...
Bing Neutral Newbie August 9, 2009 Share August 9, 2009 Hi bro's anyone knows wats the PSI for the falken 16 inch (205/45/16) tires? Thanks.. Pump ard 33-34 PSI Link to post Share on other sites More sharing options...
Nom107 1st Gear August 22, 2009 Share August 22, 2009 my 912 front right hit the sq mark other 3 tire still got the circle ( use about 25k / 1.5 years ) any1 know when to chg tire ??? can still use untill sq mark wear off ??? Link to post Share on other sites More sharing options...
Enduro25 Clutched August 25, 2009 Share August 25, 2009 wat do u mean by the square mark? Link to post Share on other sites More sharing options...
Tkseah Turbocharged August 25, 2009 Share August 25, 2009 my 912 front right hit the sq mark other 3 tire still got the circle ( use about 25k / 1.5 years ) any1 know when to chg tire ??? can still use untill sq mark wear off ??? Recommend to change tyres when thread depth reaches 3mm.. http://www.3mmtyres.co.uk/ Link to post Share on other sites More sharing options...
Nom107 1st Gear August 25, 2009 Share August 25, 2009 wat do u mean by the square mark? wear indicator : when is new see the circle on top of sq. today use ruler to chk is about 4mm depth, by the time sq mark gone think left 2-3mm only ↡ Advertisement Link to post Share on other sites More sharing options...
Falken ZIEX 914 ECORUN
Just bought new Falken Tyre
Falken Azenis FK-453
Do I need to change tyre?
Falken Launches Three New Premium Performance Tyres
Do you rate Ze912 a good and quiet tyre?
Falken Zirex ZE-912 tyres
