Noob Question On BBK
999
Normally price quote is in set of 2 or 4?
Does it include brake cables?
Brake Disc included, how many?
Brake fluid?
Brake pad included?
Do we need to re-balance the wheels?
Do we need to check alignment steering?
What happen if we closed the deal but during fitment the rims cannot fit? Any extra labour charge for the refitment after rim change?
Will it void warranty from the AD?
Thank you
Set of 2
Yes
Yes. If front, then both
Brake fluid?
Yes
Brake pad included?
Yes
No
No
Get spacer. Cut out a template and align it with your wheels first to be sure. You should be able to get the template off the respective website
Will void any brake related issues
Thank you
Brake fluid?
Brake pad included?
Thank you
Is your car a performance car?
it's all in the mind, my friend. 7 dash gauges, lowered springs, a few chassis bars and BKK, and it's a performance car already. nevermind that it's an overkill and the BBK will throw off the brake bias/balance and become more of a danger than safety feature... it's all in the mind. [rolleyes]
best to stick to bigger brands and also get one that is bolt on for your car. not those that need to customise bracket and all that. and if ends up you need to put spacer on your rims just to use the brakes, i think its not worth it.
Buying a BBK needs some research ( Car fitment , rims clearance , noise etc ).
Spend some time asking and testing other cars with BBK's would be a good start.
Spacers on front wheels is not always a good idea due to possible vibration and instability at high speeds.
