Nemozai Neutral Newbie October 30, 2009 Share October 30, 2009 guess one man's meat is another man's poison... and also different mods have different effects on diff cars... wonder which useless Mod takes the cake? Ninja? cold air charge? air-con cut off? cyclone? air charger? brake booster? magnet for the oil filter / fuel line? i even saw a fuel regulator on a stock NA car... but then maybe it was port n polished upgraded pistons... crank pully... lighten flywheel... hmmmm... ↡ Advertisement Link to post Share on other sites More sharing options...
Peaceracer 1st Gear October 30, 2009 Share October 30, 2009 Velocity tuner, abt $50. Some magnet fuel line thingy, $160... Link to post Share on other sites More sharing options...
Nemozai Neutral Newbie October 30, 2009 Author Share October 30, 2009 Velocity tuner, abt $50. Some magnet fuel line thingy, $160... its ok, lesson learnt... btw wats a velocity tuner? like cyclone? metal thingy put in before the airbox is it? next time get reviews before you buy anything... will save alot of unecessary $ spent... Link to post Share on other sites More sharing options...
Silvermini Neutral Newbie October 30, 2009 Share October 30, 2009 fancy lights for $170 now some blow liao Link to post Share on other sites More sharing options...
Silver_blade Turbocharged October 30, 2009 Share October 30, 2009 For me it has to be Cyclone. Did that mod in early 90's....couldn't feel anything. Link to post Share on other sites More sharing options...
Svtfocus Neutral Newbie October 30, 2009 Share October 30, 2009 $270 grounding cables... when same effect could have been gotten for $40... if there was an effect... Link to post Share on other sites More sharing options...
Lucaswh 1st Gear October 30, 2009 Share October 30, 2009 bodykit.... Link to post Share on other sites More sharing options...
KoseiWish 1st Gear October 30, 2009 Share October 30, 2009 Forgot the brand and cost but similar to simota spiral turbo..since fix the thing till now 2 yrs later don feel any different..and what is it use for .. Air charger bought around the same time...useless.. Regarded as useless and have to live with it... Link to post Share on other sites More sharing options...
Edca 1st Gear October 30, 2009 Share October 30, 2009 Voltage stabilizer. 5 years back and i paid about 200 plus...was been told increase HP but it's really effect only... Link to post Share on other sites More sharing options...
Kanchelsk 2nd Gear October 30, 2009 Share October 30, 2009 (edited) pivot voltage stabilizer... plus 5 point grounding... simply useless... was told can prolong battery life... yet battery die within 1 year... Simota stainless steel filter... it did improve pick up n more noise... plus more "air" flow thru with dust... in the end cost me $60 to clear the sludge in the throttle... stock is the best... Edited October 30, 2009 by Kanchelsk Link to post Share on other sites More sharing options...
Youaredie Clutched October 30, 2009 Share October 30, 2009 I added an aircon relay thermostat. Bought 2nd hand for 40 and install bout 10. Took out after 1 week cuz did not like it. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 30, 2009 Share October 30, 2009 (edited) Velocity tuner, abt $50. Some magnet fuel line thingy, $160... hahaha... i tot im the only idiot in this forum who bot a pair of magnet at $100+..... ... u really brighten upo my day! Edited October 30, 2009 by Tigershark1976 Link to post Share on other sites More sharing options...
Yuan 6th Gear October 31, 2009 Share October 31, 2009 Steering wheel cover. Makes the steering wheel look fat and more difficult to grip. I rather have the whole steering wheel leather wrapped by professional workshop. Link to post Share on other sites More sharing options...
Nemozai Neutral Newbie October 31, 2009 Author Share October 31, 2009 For me it has to be Cyclone. Did that mod in early 90's....couldn't feel anything. i really tink cyclone or anything similar is really bs... and to think that it had an original cert thingy... maybe... just maybe on the dyno you can see SLIGHT difference on the dyno... Link to post Share on other sites More sharing options...
Nemozai Neutral Newbie October 31, 2009 Author Share October 31, 2009 fancy lights for $170 now some blow liao by the way having neon lights on your car is Maximum court fine of $1000... Link to post Share on other sites More sharing options...
Nemozai Neutral Newbie October 31, 2009 Author Share October 31, 2009 $270 grounding cables... when same effect could have been gotten for $40... if there was an effect... what brand sia... $270 for grounding cables? think the effects are too minimal... logically have effect lah... all in the mind... but all in all the effects are always more felt in older cars... Link to post Share on other sites More sharing options...
Nemozai Neutral Newbie October 31, 2009 Author Share October 31, 2009 bodykit.... if it was a good quality bodykit, de-kit and sell lah... at least it did look good when you 1st bought rite? Link to post Share on other sites More sharing options...
Nemozai Neutral Newbie October 31, 2009 Author Share October 31, 2009 Forgot the brand and cost but similar to simota spiral turbo..since fix the thing till now 2 yrs later don feel any different..and what is it use for .. Air charger bought around the same time...useless.. Regarded as useless and have to live with it... i had a frd put air-charger in his YRZ... he say good leh.... but i think its riduclous... if its not on, then is there enuf openings for 'normal' air to flow through? or must be on all the time? i installed simota spiral be4... low end to mid nothing if not worse... but high-revs like smoother leh... ↡ Advertisement Link to post Share on other sites More sharing options...
Most Expensive City In the world
What kind of massage you like the most?
The world’s most powerful passports
Where is the most difficult and easiest place on Earth to gain citizenship?
Most expensive car in Singapore: Pagani Huayra
Pork fat ranked among top 10 most nutritious foods
Consolidation of useless modification (Performance parts)
ANCAP / NCAP - Most of Cat A Car lacks safety Features
