Peqasus 1st Gear November 8, 2009 Share November 8, 2009 Hey noticed my 2 yr old avante had this squeaky noise whenever if steer to the rite. Left is normal. Looks like hv to bring it back to KMC for warranty. anyone with similar issues?? ↡ Advertisement Link to post Share on other sites More sharing options...
Shingkyo Neutral Newbie November 9, 2009 Share November 9, 2009 from steering column or from the srs steering wheel? Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 9, 2009 Author Share November 9, 2009 hmmm....when i turn the steering wheel to the right, it self centres, the squeak comes. Link to post Share on other sites More sharing options...
Ericongy 3rd Gear November 9, 2009 Share November 9, 2009 this tread has been here for abt 24hr....3 posts...2 from TS.. where are all those ppl who give a tump up for avante in tread like 'avante vs forte vs cruse vs fit'? Link to post Share on other sites More sharing options...
Budgetice 3rd Gear November 9, 2009 Share November 9, 2009 u are here to start a war is it ? so ppl must start looking out for car issues to shoot each other ? Link to post Share on other sites More sharing options...
Iygnaug 1st Gear November 9, 2009 Share November 9, 2009 this tread has been here for abt 24hr....3 posts...2 from TS.. where are all those ppl who give a tump up for avante in tread like 'avante vs forte vs cruse vs fit'? Is there a need for a reply like this? It doesn't even address TS's concern. Anyway, to TS, i started having this squeaking sound from my steering wheel recently, be it left or right. It is really high pitch. After checking with my mechanic, it is the plastic/synthetic rubber rubbing against each other between the steering wheel and the mounting. Not a safety concern for my case. Make sure wheels not rubbing against fender. Perhaps, you can describe more how the squeak is like. Is it a long tone squeak, or is it squeaking at certain interval? Is the pitch high? When did it start? Does the turning feels more resistant than before? Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 16, 2009 Author Share November 16, 2009 (edited) it sounds more like 2 plastic rubbing against ea other. so far googled ard realise not many avante owners hv this problem. how to replicate squeaks - turn wheel fully to the rite, - straightening....squeak. more like squeak squeak and not a long squeak. turning feels ok. anyway booked a slot with KMC this friday to check it. driving to malacca on 27 Nov so tot better be safe than sorry. then again worried if after svcg they do more things make it worse. haiz. based on my driving habits i am not surprised right turning may hv issue. on average, i need to circle (right hand bend) 8 times up 8 times down 4 times weekly for my multistory parking. too many cars so hv to park at lvl 4. park 4 times per wk, 16 times (up down) per parking, 2 rev per time, 52 wks a yr = 6656 revolutions per yr. my avante coming to 2 yrs tat means i've turned right 13200 times more then my left turn. seems like a very unbalanced wear and tear. the qn is, i know avante is electronic steering. so wonder wat r the possible wear and tear parts. Camry has this issue acknowledged by toyota. but googled so far no much similar issues on avante. then again could be a smaller user base. Hey Lynaug, was ur problem rectified finally? or jus live with the "mice" inside the steering wheels? Edited November 16, 2009 by Peqasus Link to post Share on other sites More sharing options...
Rickster86 Neutral Newbie November 16, 2009 Share November 16, 2009 try asking them to grease the center of the the steeriing joint. might be the abrasion like u mention is 2yr old n need some greasing in it. Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 16, 2009 Author Share November 16, 2009 hopefully it's jus a lubrication problem and not a indication of a bigger problem. will keep all posted la. Link to post Share on other sites More sharing options...
Iygnaug 1st Gear November 16, 2009 Share November 16, 2009 I am driving with mice. Not too big a concern as it can't really be heard when music is on... Anyway, the road noise and engine revving sound is so much greater than the squeaking..... Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 21, 2009 Author Share November 21, 2009 heyproblems solved I reported the following issues 1) Squeaky steering wheel: They lubricated the steering column 2) Front right wheel has knocking sound over high bumps: Replacement shock gas absorber. Woohoo...now feels like the first time i took my avante. the new absorber soaks up the road imperfections better!!!! Link to post Share on other sites More sharing options...
Tweakmax2 Neutral Newbie November 22, 2009 Share November 22, 2009 is yr powersterring fluid low Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 22, 2009 Author Share November 22, 2009 avante uses electric steering lor. at least prob solved for now. will hv to monitor. Link to post Share on other sites More sharing options...
Spurman Supercharged November 22, 2009 Share November 22, 2009 this tread has been here for abt 24hr....3 posts...2 from TS.. where are all those ppl who give a tump up for avante in tread like 'avante vs forte vs cruse vs fit'? tats becoz even myself, avante owner dun hav this prob leh.. so how to comment??? Link to post Share on other sites More sharing options...
Passion 5th Gear November 22, 2009 Share November 22, 2009 My Altis(08) has this issue.Sent back to BM and got it rectified.They didnt just lub but replace the entire steering assembly.Your problem may be solve temporary.It may come back after the lub wear off.I'm similiar to you,monday to friday up and down MSCP.But I doubt is due to up ramp,if going up ramp will have this issue,then most likely the affected parts is shock/damper.And I dun always chiong up ramp,do it slow and steady.unless the rack and pinon so weak,cannot tahan up ramp. Link to post Share on other sites More sharing options...
Hog_neb Neutral Newbie December 27, 2009 Share December 27, 2009 hi all im selling off my Avante due to overseas assignment, pls have a look at my ad and revert if interested ok? $ nego comes with nice plate number. no dealers pls. http://www.sgcarmart.com/used_cars/info.ph...928&DL=1000 rgrds Goh Link to post Share on other sites More sharing options...
Bigg 1st Gear December 27, 2009 Share December 27, 2009 use peanut oil.. ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Coolant level going down
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
