Alfisti168 1st Gear August 7, 2010 Share August 7, 2010 My car's thermostat housing broke. Need to be replaced. Was quoted $110+ for the replacement of it, inclusive of labour. Is it reasonable? ↡ Advertisement Link to post Share on other sites More sharing options...
Fresh Clutched August 7, 2010 Share August 7, 2010 yes? Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 7, 2010 Share August 7, 2010 My car's thermostat housing broke. Need to be replaced. Was quoted $110+ for the replacement of it, inclusive of labour. Is it reasonable? Bro, i think you are referring to your engine coolant thermostat gasket right? I think it still user-serviceable i.e. you can DIY if you want. Try calling Song Yi and ask if they have the the Engine Coolant Thermostat Gasket. Most Stockists are CoD so you may want to pop by and buy directly over the counter if they do have it. Company Name : SONG YI AUTO PARTS TRADING 松义汽车机件贸易 Address : Blk 637, Veerasamy Road, #01-119, Singapore 200637 Telephone Number: (65) 62973700 Fascimile Number: (65) 62973839 Representatives: RAYMOND LAU Contact Name: COLIN LAU Email Address: [email protected] Bankers: OCBC Core Business: Authorised Stockist of Hyundai, Chevrolet genuine parts. Brands: HYUNDAI, CHEVROLET Link to post Share on other sites More sharing options...
Alfisti168 1st Gear August 7, 2010 Author Share August 7, 2010 (edited) Actually I not really very sure what that thing is called though. Its a hose, that sort of lost its position and fell off. The point where it lost its position is as circled in red. (btw the picture is taken from the internet. didn't have a camera phone with me so can't snap pictures.) Edited August 7, 2010 by Alfisti168 Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 7, 2010 Share August 7, 2010 (edited) How about circling the spot in this picture? it is supposed to be a snapshot of Optra's engine bay. just to be sure Edited August 7, 2010 by Happily1986 Link to post Share on other sites More sharing options...
GoodCar 4th Gear August 7, 2010 Share August 7, 2010 Tbis is a known problem for Ecotec engine. The hose housing is make of plastic. Like all plastic and rubber, they will deteriorate after sometime. They will deteriorate faster under harsh operating condition and environment. Heard that some people change it to metal housing. Anyway, all model of car will deteriorate faster when "whack" most of the time Link to post Share on other sites More sharing options...
GoodCar 4th Gear August 7, 2010 Share August 7, 2010 Your picture look more like taking from the bottom. Nice bottom Link to post Share on other sites More sharing options...
GoodCar 4th Gear August 7, 2010 Share August 7, 2010 (edited) Yes, this is the picture, I can see the hose housing from here . Did you change your water hose housing to metal one? Miss my dear Optra Edited August 7, 2010 by GoodCar Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 7, 2010 Share August 7, 2010 Hmmm like that it shouldn't be the thermostat housing liao. But if you do change the hosing, do check the thermostat housing inside to see if it is okay. If you do call Song Yi or do a quotation for repair, just say that you need to replace your top radiator hosing then they will understand. Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 7, 2010 Share August 7, 2010 Your picture look more like taking from the bottom. Nice bottom Opps heehee just now link salah picture. I drove my ex's Optra for a few months before. I like the torquey feel. I miss the "ting ting ting" noise before you insert the key and crank. Link to post Share on other sites More sharing options...
Alfisti168 1st Gear August 7, 2010 Author Share August 7, 2010 Hmmm like that it shouldn't be the thermostat housing liao. But if you do change the hosing, do check the thermostat housing inside to see if it is okay. If you do call Song Yi or do a quotation for repair, just say that you need to replace your top radiator hosing then they will understand. ok thanks lots. Hmm then in this case $110 seems a bit too expensive liao for just a piece of plastic/rubber. Oh one more thing, since all my coolant should be gone by now, should I buy my own coolant pre-mix to let them fill or should i let them top up for me, with this service being included in the labour charges? Link to post Share on other sites More sharing options...
Alfisti168 1st Gear August 7, 2010 Author Share August 7, 2010 thanks goodcar for ur inputs! did you go to songyi last time for all your wear and tear parts? if not which stockist you go to? Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 7, 2010 Share August 7, 2010 ok thanks lots. Hmm then in this case $110 seems a bit too expensive liao for just a piece of plastic/rubber. Oh one more thing, since all my coolant should be gone by now, should I buy my own coolant pre-mix to let them fill or should i let them top up for me, with this service being included in the labour charges? Hmmm i don't think they will be so nice to "bao" the cost of the engine coolant in the "labour" charge wor. I think should call them to check first. In any case if they state got to charge, i don't see why you can't ask them to charge only for labour i.e. you bring your own engine coolant. Should be cheaper than getting from them. Call me cheapo or what during servicing i bring my own engine oil etc Cheers Link to post Share on other sites More sharing options...
GoodCar 4th Gear August 7, 2010 Share August 7, 2010 Yes, I have used Songyi Link to post Share on other sites More sharing options...
GoodCar 4th Gear August 7, 2010 Share August 7, 2010 Hmmm i don't think they will be so nice to "bao" the cost of the engine coolant in the "labour" charge wor. I think should call them to check first. In any case if they state got to charge, i don't see why you can't ask them to charge only for labour i.e. you bring your own engine coolant. Should be cheaper than getting from them. Call me cheapo or what during servicing i bring my own engine oil etc Cheers Hehe....I bring my own Engine oil too Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 7, 2010 Share August 7, 2010 Hehe....I bring my own Engine oil too so bro after optra you upgraded to what ride? Link to post Share on other sites More sharing options...
Icedbs Turbocharged August 7, 2010 Share August 7, 2010 Optra is a good car....robust, torquey, and handles well. I drove one for 4 months (belongs to one of my ex..but can't remember which ex liow), good car! Link to post Share on other sites More sharing options...
Alfisti168 1st Gear August 7, 2010 Author Share August 7, 2010 Yes, I have used Songyi does songyi open on sundays? ↡ Advertisement Link to post Share on other sites More sharing options...
Citroen C4 1.2 Sensor & Display
MyResponder app to call SCDF
Help with STA report remarks
