KARTer 2nd Gear July 16, 2011 Share July 16, 2011 What's the best method to debadge badges which are not screwed on but 'glue' on? Is the use of fishing line a good way? or there are other better method? Many thanks ↡ Advertisement Link to post Share on other sites More sharing options...
D3badge 6th Gear July 16, 2011 Share July 16, 2011 What's the best method to debadge badges which are not screwed on but 'glue' on? Is the use of fishing line a good way? or there are other better method? Many thanks you looking for me? Link to post Share on other sites More sharing options...
Gaybhari 1st Gear July 16, 2011 Share July 16, 2011 Debadge for wat?? So u can replace with the badge of a more prestigious car ar?? Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 16, 2011 Author Share July 16, 2011 Debadge for wat?? So u can replace with the badge of a more prestigious car ar?? actually i hope to debadge then put "Geely".... Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 16, 2011 Author Share July 16, 2011 you looking for me? LOL.... i can help using fishing line to fross your teeth Link to post Share on other sites More sharing options...
Xspace 1st Gear July 16, 2011 Share July 16, 2011 Heat the area, then use a fishing line... Link to post Share on other sites More sharing options...
Dice 3rd Gear July 16, 2011 Share July 16, 2011 a heat gun or a hairdryer to heat up the glue so the badges are easier to be removed. thats what i did as step 1 at least. Link to post Share on other sites More sharing options...
D3badge 6th Gear July 16, 2011 Share July 16, 2011 (edited) LOL.... i can help using fishing line to fross your teeth since u wanna Floss not fross my teeth, let me teach u then. dun need fishing line as might cut ur own finger or hairdryer as normally not easy to find socket in carpark too. all u need is a credit card or use the "SIM cards plate" the plate before u take put ur SIM card. use the card slowly cut/saw the badge and it will come off. you need to have spirit to rub off the "glue mark" and wax or polish cream to polish the paint Edited July 16, 2011 by D3badge Link to post Share on other sites More sharing options...
KARTer 2nd Gear July 16, 2011 Author Share July 16, 2011 since u wanna Floss not fross my teeth, let me teach u then. dun need fishing line as might cut ur own finger or hairdryer as normally not easy to find socket in carpark too. all u need is a credit card or use the "SIM cards plate" the plate before u take put ur SIM card. use the card slowly cut/saw the badge and it will come off. you need to have spirit to rub off the "glue mark" and wax or polish cream to polish the paint thanks.... (i was wondering if it's fross or floss... kekeeke) Link to post Share on other sites More sharing options...
Darth_Goliath Neutral Newbie July 16, 2011 Share July 16, 2011 for mine,i use fishing line (fine one).spray car shampoo with water then slowly use the fishing line to remove the logo.hope this helps. Link to post Share on other sites More sharing options...
Metalsubzero Clutched July 16, 2011 Share July 16, 2011 For me I just use a plastic card like some used credit cards or membership cards.. It works.. Just need to get it between the badge and the car body.. Once in, it'll be quite easy.. Link to post Share on other sites More sharing options...
Dark_flan 2nd Gear July 18, 2011 Share July 18, 2011 I just did debadge and replaced with another badge. I used a string and let it slice in between bodywork and badge. After extracting, apply WD-40 to it and let soak about 5 mins thereafter remove residual adhensive. May take longer to remove if the adhensive is there for many years. After which may want to polish and wax affected part since there is scratches from the operation. If you are looking to stick another badge then read this - Apply some glass cleaner if you do not have alcohol swap as this will strengthen the adhensive for the new badge if required ↡ Advertisement Link to post Share on other sites More sharing options...
