Surf2004 Clutched October 22, 2011 Share October 22, 2011 Hi, My gr-90 are 40k km old now. All the tyres' side thread (lateral grooves) looks bald. Is this normal due to the thread pattern ? Or under inflation ? The circumferential grooves are still deep at about 40% left. Please comment. TIA ! ↡ Advertisement Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 22, 2011 Share October 22, 2011 Hi, My gr-90 are 40k km old now. All the tyres' side thread (lateral grooves) looks bald. Is this normal due to the thread pattern ? Or under inflation ? The circumferential grooves are still deep at about 40% left. Please comment. TIA ! u park your car at multistorey carpark? Link to post Share on other sites More sharing options...
Surf2004 Clutched October 22, 2011 Author Share October 22, 2011 Yes. Most of the time at 3 storey high. Link to post Share on other sites More sharing options...
Peregrine Clutched October 22, 2011 Share October 22, 2011 Hi, My gr-90 are 40k km old now. All the tyres' side thread (lateral grooves) looks bald. Is this normal due to the thread pattern ? Or under inflation ? The circumferential grooves are still deep at about 40% left. Please comment. TIA ! At what kilometer interval do you get tyre rotation done? Link to post Share on other sites More sharing options...
Surf2004 Clutched October 22, 2011 Author Share October 22, 2011 Rotation done at every 10k km. Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 22, 2011 Share October 22, 2011 Hi, My gr-90 are 40k km old now. All the tyres' side thread (lateral grooves) looks bald. Is this normal due to the thread pattern ? Or under inflation ? The circumferential grooves are still deep at about 40% left. Please comment. TIA ! No mention if found on all tire No mention if found only on front tire No mention if found on outboard side of all tire No mention if found on inboard side of all tire Could be done by cornering at higher speed? Could be under-inflation? Link to post Share on other sites More sharing options...
Surf2004 Clutched October 23, 2011 Author Share October 23, 2011 No mention if found on all tire ==> all tyres No mention if found only on front tire ==> front & back No mention if found on outboard side of all tire ==> outboard side, as rotation front and back No mention if found on inboard side of all tire ==> as above Could be done by cornering at higher speed? ==> exit expressway at 60-70km/hr not considered high right ? Could be under-inflation? ==> usually pump 5-10kpa above the recommended 230kpa Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged October 23, 2011 Share October 23, 2011 (edited) Yes. Most of the time at 3 storey high. okie, its the MCSP. whenever you go up, and come down from the MCSP, its only 1 side of the tyre that was worn... Edited October 23, 2011 by Tigershark1976 Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear October 24, 2011 Share October 24, 2011 No mention if found on all tire ==> all tyres No mention if found only on front tire ==> front & back No mention if found on outboard side of all tire ==> outboard side, as rotation front and back No mention if found on inboard side of all tire ==> as above Could be done by cornering at higher speed? ==> exit expressway at 60-70km/hr not considered high right ? Could be under-inflation? ==> usually pump 5-10kpa above the recommended 230kpa Link to post Share on other sites More sharing options...
Bioinformatics 3rd Gear October 24, 2011 Share October 24, 2011 Oh... i am on GR90 as well. Could it be all 4 wheel out of alightment? Need to perform some toe-in toe-out adjustment? Link to post Share on other sites More sharing options...
Surf2004 Clutched October 24, 2011 Author Share October 24, 2011 Oh... i am on GR90 as well. Could it be all 4 wheel out of alightment? Need to perform some toe-in toe-out adjustment? Quite likely. I haven't had any alignment done since the very first time I drove it. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear October 24, 2011 Share October 24, 2011 Quite likely. I haven't had any alignment done since the very first time I drove it. yup. i suspect it's due to alignment issue. issit one side of the tyre is okay while the other side (same tyre) is botak? if yes, your alignment is not right. if both sides are botak, maybe your pressure is not enough. also need to take into consideration your rim size and tyre profile. higher rim size + lower tyre profile = very fast botak for big rims with low profile tyres, it is recommended to do high speed alignment. show us some photos to ease the evaluation. Link to post Share on other sites More sharing options...
Jchuacl Clutched October 24, 2011 Share October 24, 2011 Since you do rotation quite regularly, did the tyre shop guy tell that there is something wrong or it's time to change tyres? If it looks liked cupped tyres, then probably your shocks needs to be replaced If it looks like excessive wear on one side, it could be bearing or camber issues. Run a check on google for cupped/excessive wear to verify which is the case for you. Hi, My gr-90 are 40k km old now. All the tyres' side thread (lateral grooves) looks bald. Is this normal due to the thread pattern ? Or under inflation ? The circumferential grooves are still deep at about 40% left. Please comment. TIA ! Link to post Share on other sites More sharing options...
Tcx607 4th Gear October 29, 2011 Share October 29, 2011 For GR90 tire at 40K is normal to be bald. It time to change your tire regardless to circumferential grooves conditions. You may loose grip on wet road. Be careful especically current monsoon season ↡ Advertisement Link to post Share on other sites More sharing options...
Right side speakers no sound
Need Advice On Honda Fit 2008 (GE) Side Mirror Repair
Herbal tonic wine (any side effects?)
Side mirror back cover replacement. where and how much?
Rain Shield for Side Mirror and Side Windows
SUV side step
SUV side step
Aircon not blowing cold air on driver side
