Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 So cheap ??? Where ? So far the cheapest/lightest combination I've see are some 17" ones weighing around 8.5kg each going for just over $300 each. ↡ Advertisement Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 Ok... high idle problem fixed. Seems that the micro compressors are adjustable just like Ecotek. Was set too with opening too large - ended up behaving as if trottle permanently partly open. Now things back generally to normal on idle, marginally less eager at the start (figure of course - since now starting from lower base rpm). However, at high speeds... great man... don't even have to floor or shift down in 5th gear to pull comfortably away from 90km/h to 140km/h. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie August 3, 2003 Share August 3, 2003 Hey, thut U want to get McWell to help custom make an AEM ? How's the project going along ? Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 Not yet... still debating it mentally. It's more custom dismantle an AEM - take the DC5-Auto AEM CAI - which just barely fits, and cut one/two joints to fit it in. Except I think they fresh out of stock of DC5-Auto ones - next shipment. Link to post Share on other sites More sharing options...
Arkaneslayer Neutral Newbie August 3, 2003 Share August 3, 2003 Just installed two Micro Compressors into my St-R-eam, . pardon my ignorance ... what is a Micro Compressor & what does it do? Link to post Share on other sites More sharing options...
GDIzen Neutral Newbie August 3, 2003 Share August 3, 2003 Normally, we don't need kickdown from 5th to 4th gear at expressway speeds...You mean with full load of 7 ppl is it? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 3, 2003 Share August 3, 2003 Oh ya,...forgot you got lessons going on now....maybe catch up with you for lunch lah.... Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 From what I understand, it's a 'controlled' leak - attached to the vacuum hoses, so that air can be brought into the combustion chambers - more air (within certain proportions) translates to more power. Several on the market - Ecotek, Super Airmax 2, and this one. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 If you cruising, and wanna accelerate, for 5 speed auto, power distribution usually just not there. For Stream, 5th gear cruising 90-100km/h is around 2000rpm - so if you wanna accelerate, usually there's fair bit of 'reluctance' to climb the rpms - usually would need to step harder for kick-down to 4th gear to push into higher rpm range to improve power. At least that's my experience with my car so far. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 3, 2003 Share August 3, 2003 how much did you paid for yours? Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 $170 a piece w/installation (which for my car included taking out the bumper ) Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 3, 2003 Share August 3, 2003 so for your case, it is well worth the money lah?.... Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 3, 2003 Author Share August 3, 2003 I suppose ok lah Guess they didn't expect to incur so much more labour cost Link to post Share on other sites More sharing options...
Saaber Neutral Newbie August 3, 2003 Share August 3, 2003 Yep, guess they didn't see that coming.... Link to post Share on other sites More sharing options...
Chippz Neutral Newbie August 4, 2003 Share August 4, 2003 Actually, quite sad... because kinda ran out of things to do. Actually was not intending to do this one, since already got Ecotek. Decided to try only after Myskyline told me it worked pretty well on his JDM Accord (actually he put one, and when it worked well enough, he put another). Now got Ecotek to get rid of. maybe you can try selling it off at mycarxchange? Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 4, 2003 Author Share August 4, 2003 Anyway, to be nice, I agreed to put on the wire mesh since they had the bumper out. Good to keep out leaves and stuff anyway. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie August 4, 2003 Author Share August 4, 2003 Done that. Waiting for takers. Link to post Share on other sites More sharing options...
Chippz Neutral Newbie August 5, 2003 Share August 5, 2003 best of luck to you.. ↡ Advertisement Link to post Share on other sites More sharing options...
Air-Con Compressor Spoilt
A/C repair in JB
A/C repair in JB
Need advice for Axio repair cost
Aircon compressor replacement for Hyundai Avante
Use aircon compressor to dry bak kwa
Air compressor - convert from screw-in to clip-on
Aircon Compressor per-char liao
Noisy aircon compressor
