AirMax
Dylanng
Hi guys,
Just wanna find out if AirMax, micro air compressor will help to enhance the car power as it will force more air into air intake system....
Thanks...;)
yo guys...
thanks for the recommendation...pm me as I'm interested to find out more it...
cheers....
Hi guys,
Thanks...;)
Answer - yes.
Hi ModelDriver,
Does ecotek or airmax lose all its performance after some time? I am using stock ECU and I think the ECU might compensate and then "shift" itself back to normal again. So ecotek or airmax after a few weeks become a waste of money. Please advise. Thanks!
that's what some people say... in my case though not really, because I've got a piggy back to my ECU that overrides the ECU's a/f ratios... which means I can maintain the same performance level set after a dyno tuning.
on the other hand, makes me wonder on the claim. The ECU basically controls a certain a/f mix, which is usually on the rich side. putting something like this in leans out the mix. If the 'leak' comes in after the air flow sensor, then the ECU won't know about it, and the improvement should remain. If it is not, the ECU may compensate by injecting more fuel, but then you still get good performance w/o stepping as hard on the accelerator in theory ?
Of course, there's also the Ecotek and airmax loosing effectiveness from its own filter getting clogged up ! [laugh]
What you say makes sense. But if the ECU compensate by injecting more fuel, then we must be careful how much we step on the accelarator. If not, we could easily overrev and thus waste even more fuel.
So in your opinion, should we go for the piggyback first or should we put in airmax or ecotek before we do the piggyback?
Thanks for advise!
They don't "force" more air into the intake system, only "let" in more air by utilising the vacuum in the PCV. MicroCompressor's name may make it sound like it compresses the air just a micro bit, but I doubt it, as there's nothing in it that compresses air.
By pure fluid dynamic explanation, by having a cone shape funnel, does air "automatically" get compressed as it goes narrower through the cone or does it just let a fixed amount of air through in a "queue" ? If it is, where does all the other air goes to ?
If you put your palm on the MicroCompressor, it can get sucked in and requires considerable force to remove your palm .. if these air are not going anywhere (bypass), the only path is into the engine ... and through the 5mm tube, it had to be compressed right ?
Eer... I can't answer yr questions... guess you'll need to Tee out a vacuum/boost gauge after the MC to know for sure!
My guess is that there's still vacuum after MC, maybe lower than before installing it, but nevertheless still vacuum.
Think the comments here are correct. It really suck air into a very narrow path causing an increase in pressure, guess this can be called compression no doubt.
So guys and gals, does it after a few weeks? Still having the improvement?
Dun except lof of power gain,maybe a bit more torque
then again after two week of driving,u wun feel a diff [:/]
Do join us for meetup for more info [thumbsup]
