Ace_t Neutral Newbie November 13, 2003 Share November 13, 2003 yeah.. good point on finding out what those guys did. we won't know if they probed a tuning tool into the ecu and did some tuning. afraid that they changed some values on the PROM. so maybe resetting the ecu won't help. keeping fingers crossed. ↡ Advertisement Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 13, 2003 Share November 13, 2003 go sungei road there lor...got some spare parts shop there selling Hyundai part...definitely cheaper then getting from komoco...i get mine there too.. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 13, 2003 Share November 13, 2003 try a few stockists. my usual bet is to try either Sin Ming, Waterloo street or even Bukit Merah/Alexandra--opp Bukit merah SAFRA (near yr workplace) Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie November 13, 2003 Author Share November 13, 2003 Sorry for bad English. Regarding the cruise thingy, what I meant was normally I just accelerate to before 2500RPM and the gear will shift till 100KM/H, then crusie at 2000RPM. Now must step to 2800RPM to 3000RPM then the gear shifts up to 100KM/h, then cruise at 2300RPM. Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie November 13, 2003 Author Share November 13, 2003 Have we met? How you know I work near Bt Merah . Anyway, I think I will try calling TLW and ask if they do it for me how much, compared to DIY. Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 13, 2003 Share November 13, 2003 so that mean least time at 100km...the rmp is 2000...but now at 100km the rpm is 2300 har ??? ha ha ha..very chim...cause if like this maybe the gearbox did not switch to overdrive...and stay at the 3rd.... Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 13, 2003 Share November 13, 2003 hate to think that maybe it's a gearbox problem, now that u explained it in more detail. is yours an AUTO ? is yes, then check the gearbox cable that senses the throttle cable to allow for gear shifts...maybe that one is loose...(being optimistic) Regarding the cruise thingy, what I meant was normally I just accelerate to before 2500RPM and the gear will shift till 100KM/H, then crusie at 2000RPM. Now must step to 2800RPM to 3000RPM then the gear shifts up to 100KM/h, then cruise at 2300RPM Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie November 13, 2003 Share November 13, 2003 wah liao.. of course we hv met. at gilman's wif yr kiddie .. dun forget me so fast leh.... Link to post Share on other sites More sharing options...
Vidz 6th Gear November 13, 2003 Share November 13, 2003 yah.. maybe the deleted the Turbo subroutine.. Link to post Share on other sites More sharing options...
En0203 2nd Gear November 13, 2003 Share November 13, 2003 don't think 3rd gear can reach 100 km/h at 2.3k rpm bah Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie November 13, 2003 Author Share November 13, 2003 Overdrive sure engaged and should be working properly. I used it often as engine brake Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 13, 2003 Share November 13, 2003 humm..then i also bo idea liao...last time i also drive an year 2000 model accent...but the manual 1... Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie November 13, 2003 Author Share November 13, 2003 Pai say, pai say. Next time, I try to recall. Link to post Share on other sites More sharing options...
Seaweed 1st Gear November 13, 2003 Share November 13, 2003 humm...you are right.... Link to post Share on other sites More sharing options...
Vidz 6th Gear November 13, 2003 Share November 13, 2003 Sorry for bad English. Regarding the cruise thingy, what I meant was normally I just accelerate to before 2500RPM and the gear will shift till 100KM/H, then crusie at 2000RPM. Now must step to 2800RPM to 3000RPM then the gear shifts up to 100KM/h, then cruise at 2300RPM. 100kmh @ 2000rpm? 100kmh@2300rpm seems more appropriate... not sure... upshifting controlled by ECU... your tranny still young lah.. don worry.. should be fine after resetting ECU.. although will take sometime for it to learn.. Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie November 13, 2003 Author Share November 13, 2003 yeah.. good point on finding out what those guys did. we won't know if they probed a tuning tool into the ecu and did some tuning. afraid that they changed some values on the PROM. so maybe resetting the ecu won't help. keeping fingers crossed. But the ECU worked fine for 8 days? If they changed the program, normal procedure should be initiate a reboot and test if program working. So I should be using the new program from day 1. Now need to test so many things 1) Reset ECU 2) tyre pressure 3) fuel filter/gearbox Link to post Share on other sites More sharing options...
Vidz 6th Gear November 13, 2003 Share November 13, 2003 (edited) simply lah.. if 1 & 2 works... can forget 3.. if 1 & 2 dont work, do 3.1 (fuel Filter) if 3.1 doesnt work.. then BIG sxxt liao.. 3.2 Edited November 13, 2003 by Vidz Link to post Share on other sites More sharing options...
Jimmyl Neutral Newbie November 13, 2003 Author Share November 13, 2003 Sure. 1 & 2 FOC 3 cost money OK. Let you gurus know the outcome on Monday. Till we have more suggestion.............................. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Getting a foreign wife
