Zirco Neutral Newbie July 31, 2002 Share July 31, 2002 Guys, my power window broke last night sigh! Think the motor still working. But think something else broken so can move down (open) but cannot move up (close). Can tell me what's the damage ($$$$)? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Yongwd 1st Gear July 31, 2002 Share July 31, 2002 its broken window regulator, what car u driving? Link to post Share on other sites More sharing options...
Zirco Neutral Newbie July 31, 2002 Author Share July 31, 2002 Ibiza. The driver side one. sigh! Link to post Share on other sites More sharing options...
Yongwd 1st Gear July 31, 2002 Share July 31, 2002 find ur stockist and DIY if u can. Pretty simple for jap cars, not sure for VW/Seat Link to post Share on other sites More sharing options...
Zirco Neutral Newbie July 31, 2002 Author Share July 31, 2002 Oic Thanks! Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie July 31, 2002 Share July 31, 2002 All windows button tested? Fuse? if everything ok, then must open to take alook. Link to post Share on other sites More sharing options...
Zirco Neutral Newbie July 31, 2002 Author Share July 31, 2002 yeah! all tested and working. Will be going down to my mech to check first. Link to post Share on other sites More sharing options...
Lester Neutral Newbie July 31, 2002 Share July 31, 2002 Sounds like a snapped belt in your window pulley. Lester Link to post Share on other sites More sharing options...
Sky8807 1st Gear July 31, 2002 Share July 31, 2002 something dislodged, either broke off due to corrosion or fatigue. Another possibilities is the linkages drop off its position. Only way to confirm is to open up the door panel to look. Link to post Share on other sites More sharing options...
Cordoba708 Neutral Newbie July 31, 2002 Share July 31, 2002 Guys, my power window broke last night sigh! Think the motor still working. But think something else broken so can move down (open) but cannot move up (close). Can tell me what's the damage ($$$$)? Thanks! Zirco, If you go to BM ......it'll cost you up to about SGD 500 thereabouts.......outside...dunno about United, but I'd expect it'll cost you about SGD 280 at somewhere like Servotronics. If you have 'kang tao' at scrapyards, it'll cost you only about 100+ but no guarantee that it'll last cos it's been used before, and for your info, the sets are side / direction centric......meaning if you are thinking of taking out motor and regulator from side passenger door.. ....u cannot do so cos it is designed for the specific door unlike Jap cars where there are generic sets..... Cordoba708 Link to post Share on other sites More sharing options...
Zirco Neutral Newbie August 1, 2002 Author Share August 1, 2002 Just checked with BM think usual price is S$495. So expensive but but... they give discount. hee! hee! Anyway checked with kian hua and they quoted a reasonable price for a OEM set. Will be looking around somemore before i decide. Thanks to all guys here for advice. Link to post Share on other sites More sharing options...
Yongwd 1st Gear August 1, 2002 Share August 1, 2002 $495 for a window regulator??? I can buy 6-7 toyota originals for replacement!! Link to post Share on other sites More sharing options...
Zirco Neutral Newbie August 1, 2002 Author Share August 1, 2002 not the regulator. It's the whole unit including the motor. Anyway they give discount so cheaper than the quoted price. Link to post Share on other sites More sharing options...
Eliew Neutral Newbie July 16, 2003 Share July 16, 2003 Hi, Just discovered I could not wind up my power windows all of a sudden. Any recommendations for a cheap and reliable workshop for repairs? thanks million! Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear July 16, 2003 Share July 16, 2003 Sometimes, it might not be the motor that gives you problem.. It could be due to the switch too., Link to post Share on other sites More sharing options...
Eliew Neutral Newbie July 16, 2003 Share July 16, 2003 Thanks but think my motor's ok as I could hear it running. it could wind down but not up (same problem as the originator of this thread reported). More importantly, are there any recommendations on a gd workshop to send the car for fixing? I have called up CAS and understand they do, just not sure how much. Rgds Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear July 16, 2003 Share July 16, 2003 Try asking these 2: Company Name: BMS Motorsport Address: 10 Ang Mo Kio Industrial Park 2A, #02-01, Autopoint Building, S(568047) Tel: 9026 9696 Email: - Contact Person: - Remarks: Subaru specialists. -------------------------------------------------------------------------------- Company Name: BVO Automotive Address: Blk 15, Sin Ming Industrial Estate, #01-111, S(575673) Tel: 6455 1566 Email: [email protected] Contact Person: Bernard Sim (HP:9682 5571) Remarks: Specialise in BMW servicing & repairs, Broquet, suspension systems, lowering springs. Link to post Share on other sites More sharing options...
Cool Neutral Newbie July 16, 2003 Share July 16, 2003 What is your defination of "KAPOO".. is it broken into pieces? Sometimes, when water sip into the motor, it just would not work. You need to spray WD40 to get rid of the water. Before you do that, use a multimeter and test the connectors into your power window motor and see is there electricity. Unlikely it KAPOO, cos it was raining heavily and water may be the cause. my 2 cents.. if it works, you need not spend $$$ on a workshop. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
