Vass Neutral Newbie December 22, 2003 Share December 22, 2003 Dunno is it due to the heavy rain recently, have noticed water flowing down on the front passenger side floor board. Have anyone encountered this b4 ? Will air-con leak water into the car ? also I changed the pollen filter 2 weeks ago (DIY), can water enter from the filter compartment ? Anyone with similar encounter or any good workshop to recommend ? ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator December 22, 2003 Share December 22, 2003 "......have noticed water flowing down on the front passenger side floor board. Have anyone encountered this b4 ? Will air-con leak water into the car ?......" Check the rubber seal at the front of the car, could be possible leak. Had it once on my old jalopy...amount of h20 could rear an arowana liao...after every rainfall, have to squeegee water out.. Link to post Share on other sites More sharing options...
Buzz Neutral Newbie December 22, 2003 Share December 22, 2003 Your next car don't close top can become a bath tub Link to post Share on other sites More sharing options...
RadX Moderator December 22, 2003 Share December 22, 2003 Was thinkin more of jacuzzi... Link to post Share on other sites More sharing options...
Super7 Turbocharged December 22, 2003 Share December 22, 2003 if the leak only starts when you use the aircon, it's likely that the aircon drain pipe is choked..... it's quite easy to clear the choke if it's caused by dirt/mud stuck at the outlet..... try to locate the outlet (different cars use diff positions) and use a screw driver / pencil etc to clear the mud... Link to post Share on other sites More sharing options...
Lordgt Neutral Newbie December 22, 2003 Share December 22, 2003 har this is serious sxxt man.. did you wind up your windows all the way?? or could it be the rubber packing that is already worn?? Link to post Share on other sites More sharing options...
Phalanx Neutral Newbie December 22, 2003 Share December 22, 2003 Dunno is it due to the heavy rain recently, have noticed water flowing down on the front passenger side floor board. Have anyone encountered this b4 ? Will air-con leak water into the car ? also I changed the pollen filter 2 weeks ago (DIY), can water enter from the filter compartment ?Anyone with similar encounter or any good workshop to recommend ? Think it is best to double check the fitment of the pollen filter as I heard that if it is not fitted properly, water can leak from there. Link to post Share on other sites More sharing options...
Vass Neutral Newbie December 23, 2003 Author Share December 23, 2003 Thanks for all the advice. Maybe not the air-con b'cos yesterday no rain and no h20 drip down. I think need to re-check the pollen filter fitment - Xiong... took me a long time to fit it in the last time.....hope it wun happen to the rest. ↡ Advertisement Link to post Share on other sites More sharing options...
Cost of parquet flooring and laminate flooring
Any good lobang for good price flooring and aircon
Laminate flooring
Laminate flooring
Office flooring mat
Office flooring mat
Changing flooring tiles
