S2P2 Neutral Newbie January 2, 2004 Share January 2, 2004 so have you tried on the G9? ↡ Advertisement Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie January 2, 2004 Author Share January 2, 2004 No, G9 owner(my brother) not interested. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 2, 2004 Share January 2, 2004 then no test results liao..... Link to post Share on other sites More sharing options...
Greenelantra Neutral Newbie January 2, 2004 Share January 2, 2004 How much is this venturi thingy,I saw a place selling 238,is it ex? Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie January 3, 2004 Author Share January 3, 2004 Thats like $100 more than ecotek!!!!!!!!!!!!!!. Ex Ex Ex Link to post Share on other sites More sharing options...
Bfmstg Clutched January 4, 2004 Share January 4, 2004 well actually the venturi is a replica from turbo-in or yokokaya. it's work like e68 or airmax 2 but the different between the others are manually adjustable. this one is auto adjust with a pressure spring built inside (factory fixed). not sure about the version now but i got 2 units installed on my previous ride. got better pcikup and throttle response. as for fuel consumption not so much different. i ha not see the mechanism inside the venturi but what i have one need to clean and change the filter sponge every month to maintain the performance. you will be surprised how dirty is the sponge. i bought them at $120 each with installation. now all sold due to changed of vehicle. you can get them at $50 to $60 for a used one. regards Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie January 5, 2004 Author Share January 5, 2004 (edited) Thks for the explanation. BTW, isssit self adjustable at diffrent rpms or just means u dont have to dial in manually at idiling? I think the $200 plus price is rather ex if what one of the other guys posted is accurate. Edited January 5, 2004 by Throttleb Link to post Share on other sites More sharing options...
Bfmstg Clutched January 5, 2004 Share January 5, 2004 (edited) or venturi shoudd be "auto" which mean a spring load is preset. but after that preset, its will actually cut off. sorry i'm a layman and not good in explanation. the "cut off " meant the air is larger when reached above 4ooorpm so eventually the venturi or turboin wont be doing any more load since factory set at 3000rpm or 3500rpm air suction load. manually adjustable type are like e68, airmaxx 2 or powerjet etc. the adjustment made to suit individual needs. for venturi or turbo in is factory preset. but can do manually but very troublesome. well hope my "ang mo" explanation you can understand, pie say. regards Edited January 5, 2004 by Bfmstg Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie January 9, 2004 Author Share January 9, 2004 Thanks,very good explanation I see that e68 has diffrent uses apart from mounting at entry point to inlet manifold.. any idea why. Link to post Share on other sites More sharing options...
Azrielsc 1st Gear January 9, 2004 Share January 9, 2004 Hello, just came across this thread. Have the Venturi1 on my bimmer for the past 3-4months. I was sceptical at 1st cuz i don't believe in these kind of gadgets but after a friend of mine tested for about 2 months before me, and judged it good, before i took the plunge. Acceleration from start-stop traffic was an improvement then before and my fuel consumption dropped slightly. As someone just using it... that's all. But the pickup is noticeably quicker... 1 Venturi1 is only good up to 2.6L... anything bigger like 3L engines and above, 2 Venturi1s should be used. Link to post Share on other sites More sharing options...
Throttleb Neutral Newbie January 9, 2004 Author Share January 9, 2004 (edited) Thanks for the update, would like to clarify if: 1)Its T'd off the brake vacuum line that leads to inlet manifold 2) any hissing noise 3)its efficacy at high end. I surmise you described better low end pick up. I;m now trying to help someone put a little zest in a new Honda city. Edited January 9, 2004 by Throttleb Link to post Share on other sites More sharing options...
Azrielsc 1st Gear January 9, 2004 Share January 9, 2004 Okay. 1. Yes. 2. NO hissing or tuning needed like ecotek 3. Low end acceleration is noticeable but not high end. Very nice for city driving! Good investment and its not that expensive too Link to post Share on other sites More sharing options...
Bfmstg Clutched January 9, 2004 Share January 9, 2004 e68 actually can mount on throtlle body, manifold etc. but depends on cars and made. for the venturi thingy, just have to remind owner to check the sponge inside and also the sunction volume. too rich might cause higher fuel consumption. to low got no imporvement overall. the one i used to have actually got hissing sound when idling and brand new. after a period of time, you will notic the hissing getting lower due to the sponge too dirty to allow airflow. just try to maintain the item may serve you well. also make sure the pipe provided can withstand high temperature. it happened to us before. all the pipe become out of shape a fter a few month and this will cause hazrard, which meant no good for drivers. regards ↡ Advertisement Link to post Share on other sites More sharing options...
Venturi cone for CAI Pipe
Cockroach thinggy
Cockroach thinggy
