Yongwd 1st Gear August 22, 2002 Share August 22, 2002 I solve my the wooo wooo whisling sound on my old old corolla - its due to a shrink rubber seal on the door mirror. Added silicon and reinstall the door mirror. The sound is gone permanently. Perhaps you wan to check yours ? ↡ Advertisement Link to post Share on other sites More sharing options...
Freemason Neutral Newbie August 22, 2002 Share August 22, 2002 say, you coming for the meetup tonight? perhaps you can show me where to add the silicon and stuffs Link to post Share on other sites More sharing options...
Yongwd 1st Gear August 22, 2002 Share August 22, 2002 not a problem Link to post Share on other sites More sharing options...
Freemason Neutral Newbie August 22, 2002 Share August 22, 2002 thanks dude, i owe u 1 Link to post Share on other sites More sharing options...
Rock Neutral Newbie August 26, 2002 Share August 26, 2002 Hi Freemason Did you get your woo woo sound fixed...one way is to drive slowly...but..... Anyway, I got the problem by the dealer...think they opened up the inside door panels and re-align/tighten the sub-frame....that was one time when I was driving a civic. But on another car, Accord...I had the same problem...cause I cont to smoke and open/close door 10 times a day...they told me I had to change to entire door frame... and I told them to forget it. Just turn up my ICE a bit louder....solved the problem... at least I cannot hear. Rock Link to post Share on other sites More sharing options...
Lester Neutral Newbie August 26, 2002 Share August 26, 2002 Hi LS One thing you can do is actually tuen up your a/c full blast, turn up your ICE and hear, feel for cold air and bass vibrations from along the edges. Once detected, open up door and study how well the door is closing on that partcular part. Try things like squeezing on the particular area abit or putting some thick double sided tape over to see if it reduces the vol, cold air. If yes, maybe the double sided tape without peeling the door side off can work fine or you can trim down a aerofoam pc? Lester Link to post Share on other sites More sharing options...
Lightspeed Clutched August 26, 2002 Author Share August 26, 2002 just found out that front passenger door also eating wind....haiz Link to post Share on other sites More sharing options...
Lester Neutral Newbie August 26, 2002 Share August 26, 2002 LS Problems like this you need patience to slowly fix them. It's just like trying to detect a faint creaking sound from somewhere. It might take months up to yrs! Give my method a try by using a/c and ICE then try sealing with tape or foam b4 you try more expensive means. Lester Link to post Share on other sites More sharing options...
Freemason Neutral Newbie August 27, 2002 Share August 27, 2002 dude rock, havent got the woo woo sound solved ya,drive quite slow already...and got lots of honking in return and looks like i gotta input ice to cover up that woo woo woo Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear August 30, 2002 Share August 30, 2002 Try this before you yank your rubber out. Using a paint brush....apply amourall or similar products to the rubber...coat it till its wet (but not dripping). Then leave your doors open while the liquid dries on the rubber. After that, use a small piece of tissue or sponge to soak up the left over amourall and try if the wind noise is still an issue or not. This may work if the rubber is not oxidies yet....the amourall will help make the rubber more supple and thus sealing better. Hope it works for you....works for me !! Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 30, 2002 Share August 30, 2002 Same old trick.. but AutoGym Bumper Polish is better... it last longer. Alternative use Dupont Telfon spray... which I am using now. Link to post Share on other sites More sharing options...
Huggable Clutched August 31, 2002 Share August 31, 2002 Word of caution, the silicon thingie is very smelly! Might have to live with it for a few days before the smell goes away. Quickest method is to pull the rubber lining and then use silicon and apply to the metal and stick it back. Else, can source this rubber frmo Cuff road. Link to post Share on other sites More sharing options...
Cool Neutral Newbie August 31, 2002 Share August 31, 2002 The new ones no that bad... don't buy the cheapos.. it goes away probably 30 mins. buy Shelly's Link to post Share on other sites More sharing options...
Huggable Clutched August 31, 2002 Share August 31, 2002 I'm also having wind-noise problems with my car Need to get down to work soon I guess... will remember Buy Shelly's Link to post Share on other sites More sharing options...
Cool Neutral Newbie September 1, 2002 Share September 1, 2002 want to get from me instead of buying.. cos if I don't finish it, it will dry up... ↡ Advertisement Link to post Share on other sites More sharing options...
'protection' against door bang
Door Protector Stripes, an important exterior feature against dings?
Where can I get rubber sheet
Digital Door Lock
Digital Door Lock
Drive shaft rubber boot/cover
Hdb main door
Hdb main door
