Madarmour Neutral Newbie February 18, 2004 Share February 18, 2004 At least you have me in your camp. I switch off everything too before switching off my engine. ↡ Advertisement Link to post Share on other sites More sharing options...
Konspire Neutral Newbie February 18, 2004 Author Share February 18, 2004 rite on, mate. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie February 18, 2004 Share February 18, 2004 the only thing that's left ON for me is the radio. Anyway there's a relay to cut off the power to the radio when you crank the car. Unless you have lot's of ICE with a woofer pounding away, the HU draws very little current from the battery. I would usually let the car idle a few secs before turning on the aircon. This allows the car to get it's engine on stable-mode before adding an extra load. Link to post Share on other sites More sharing options...
Seaweed 1st Gear February 18, 2004 Share February 18, 2004 ya...think probably will not have any harm but then turning off will be a good practise... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2004 Share February 18, 2004 Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2004 Share February 18, 2004 (edited) rightfully, you should off everything. when you just start you engine, at the instance of turning you ignition, the car is drawing HUGE power from your battery to run the engine. If you have your aircon and ICE on, these 2 items are individually drawing big power from your battery as well. Try imagine 3 stuff drawing all power at the same time. Its not that you will have big problems, but you would be shortening the life span of the battery and contrary to popular believe, your alternator do not start charging one its is started. It only starts at a certain rpm and that is dependent on car. but should be the range of 1300 - 1500 rpm.....so basically with no charging, you are subjecting the battery to high stress with that may gadgets drawing power at the same time. Edited February 18, 2004 by S2P2 Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie February 18, 2004 Share February 18, 2004 I think cranking the engine itself use up most of the battery's power. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2004 Share February 18, 2004 I think so too, but dun have the actual figures.....so if we both are right that it drains most of its power, imagine the ICE and the aircon turning on at the very same instance Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie February 18, 2004 Share February 18, 2004 At most change battery early lor.... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2004 Share February 18, 2004 piangz.....as it is, our climate already shorten its life liao, we still go and shorten it eh, PM me your lobang Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 18, 2004 Share February 18, 2004 is it a good practice to switch on/use the radio or cd while the engine is turned off? will it effect the batter life or anything like that. or even use the power windows while the engine is off. some ppl i notice that they never switch off their aircon n radio when they turn off their engines. so when they start the car, these items hv started already. any impacts? thx guys.....juz to share... yes, best is to off everything before switching off car Link to post Share on other sites More sharing options...
Konspire Neutral Newbie February 18, 2004 Author Share February 18, 2004 n dun 4get the cabin light....... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2004 Share February 18, 2004 what talking you Link to post Share on other sites More sharing options...
Konspire Neutral Newbie February 18, 2004 Author Share February 18, 2004 no lah...i meant if u hv the HU n aircon on, u also have the cabin lights on if u open the door, so better to off everything n start the engine wif the door closed. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2004 Share February 18, 2004 how much is the cabin light drawing as compared to the HU and aircon? Link to post Share on other sites More sharing options...
Konspire Neutral Newbie February 18, 2004 Author Share February 18, 2004 tonite i go n check. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 18, 2004 Share February 18, 2004 I normally switch off my A/C and Radio before I turn off my engine,. Link to post Share on other sites More sharing options...
Epsilon 2nd Gear February 18, 2004 Share February 18, 2004 I normally switch on my A/C after I turn on my engine ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommendation for good facilities Health Centre/ Spa
Harddisk Diagnostic Test Software - Any good & free ones to recommend?
Any good private driving instructor to recommend?
Pls recommend good urologist
