Car Sound - Part 1
E36UDM
Polk on Car Sound - Part 1
What you really need to know! http://www.autospeed.co.nz/cms/A_1203/emailit.html
http://www.autospeed.co.nz/cms/A_1203/printArticle.html
Courtesy of Polk Audio The Basics - or Stuff You Gotta Have Head Unit 1203_2lo.jpg
The head unit is the tuner, cassette deck, or CD player that sends the signal to the rest of the system. Some head units have amplifiers built in (in which case you must make sure your speakers are efficient enough to play loudly with the relatively small amount of power in most head units!).
On a budget? Buy speakers first. Better speakers can make your stock head unit sound really good. You can upgrade it later. And you will want to. One thing to keep in mind: make sure the head unit has pre-amp outputs when you buy it. You'll need them when you're ready to add amplifiers later. Speakers 1203_3lo.jpg
Ultimately, the head unit source sends its signal to the speakers. Your speakers determine how your whole system will sound. No equalizer, amplifier, or processor can compensate for poor (or poorly installed) speakers. Even if you're on a budget, you should plan on spending the bulk of your allotted expenses on your speakers. (And if you're really on a budget, plan on a head unit and a set of speakers now, and worry about amps and processors later.)
Subwoofers are the speakers that deliver the lower frequencies of the audio spectrum. They need to be specially installed, usually in a box designed specifically for them. They demand more power to play at acceptable levels without distortion, which brings us to... Amplifiers 1203_5lo.jpg
An amplifier boosts your signal power, resulting in a cleaner sound and more volume. And because more power is a good thing, an amplifier might be the next thing on your list. Be careful, though, because if you are planning on adding several high power amplifiers you may need to upgrade your car's electrical system with upgraded capacitors, battery, and - lastly - alternator.
Amplifiers can really turn your system on. With more power you'll achieve a cleaner, more dynamic sound at higher volumes.
But installing an amp yourself can be tricky.
Be sure to plan your install carefully. Never mount amps or other components directly to the metal of your car. (That's just asking for noise problems.) Instead, use screws with rubber isolators when you have to mount to metal, or mount the component to a non-conductive board and then mount the board to your car's body. And before you drill holes to mount anything, hook the component up and give it a test run in your chosen location. How smug will you feel after finding that a noise problem can be fixed simply by moving your amp to a new location... before you've drilled!
Amps are sensitive to electrical and motor noise, and they can interfere with your radio reception. They should be mounted at least 1 metre away from your head unit. 1203_7lo.jpg
You can mount an amp under a front seat. This is close to your head unit, so you'll be able to use shorter cables to both the head unit and the speakers, but larger amps won't work here. Mount an amp on the passenger side firewall - you won't have to remove the seat, but again only a very small amp will fit. Better yet, mount your amp in your boot, where it will have plenty of room to breathe, which is important because...
Amps produce a lot of heat. You'll see cooling fins on an amp. They radiate that heat into the surrounding air to help cool the amp. For these fins to operate properly, they need at least 50mm of air space around them at all times. Also, try to keep them vertical. Amps should not be mounted with the fins facing downward because heat will convect back up into the amp.
A tip: Just because something is metal doesn't mean it's a good ground. Ground your amp directly to areas of heavy chassis metal only, not to a piece of metal that's merely attached to the chassis. Use maximum ground wire run-lengths of 45 - 60cm. More Stuff You Need
These are good times. There is no end to the cool stuff you can add to your car audio system these days. From the biggest, baddest sub-woofers, to computerized navigation systems (some that are even voice-controlled). Soon, you'll even be able to get your hands on complete DVD "car theatre" systems. The options are endless.
What's more, there is even some cool stuff that you positively need (as opposed to the cool stuff you just want), like this: 1203_8lo.jpg
You'll need RCA cables to carry pre-amp (low line level) signal, usually from your head unit to your amp and processors (crossovers, equalizers, etc.). Get 'em well-built, flexible and shielded, with sturdy connector ends that will withstand the stresses of car audio connections. It pays to buy quality cables. 1203_9lo.jpg
Amplified signal (especially when it's going to your subwoofer) is much stronger, and requires a more capable cable. There's a lot of current zipping out of your amps. That's why they make speaker cables. Be sure to use cable that is 16 to 8 AWG (gauge) for subs and coaxes. (The lower the number, the thicker the wire, the less resistance - thicker is better.) Tweeters and mids can use thinner cables (16-12 AWG). 1203_10lo.jpg
For battery connections, a power distribution block can make wiring multiple electronics a breeze. Run a 4 to 6 AWG power cable from your battery to a power distribution block and use its multiple outputs for each component. Some power distribution blocks even come with their own fuses to protect your components. You can also find battery terminals that have secondary connectors to let you easily hook up the extra power cables. Told you it was a good time!
To easily integrate a head unit to your car's factory wiring, use a wire harness. It allows you to do all sorts of alterations without harming your car's factory wiring. You want to replace your stock head unit, but you don't want to have to leave your custom unit in the car when you sell it in a year? So you use a wiring harness that's designed for your car model, and you can remove your stock head unit and attach a new one without cutting the original wiring. The custom unit just plugs right in to the harness!
http://www.polkaudio.com/car/
Next week: speakers
http://www.autospeed.co.nz/cms/A_1203/article.html
Edited by E36UDM
