IMPROVING PICKUP SPEED
RedM623
How abt getting an E68 or Airmax2 kind of gadget for a start? This one no need to mod, its an add-on.
this only lean out the air mixture & it's not too good as the additional air going in are unfiltered [unimpressed]
i get very sensitive when 2 2s are used together
thanks for the advice...
the ride is an auto but can also use manumatic to run for a change..
Piggy back...hmmm..will it cost a lot..
i am a novice in add-ons and mod...need some of u gurus to enlighten..
wah... all along i tot theres a washable filter inside this gadget. Then even if theres improvement the engine will be dirty too...
A piggyback will be a good investment in a long run. Transferable too. Depending on the kind of piggyback and their functions, it will range betw 500 - 600 w/o installation and tuning.
I get sensitive when i hear 21 n 25 [cool][cool][cool][cool][cool][tongue]
i got a feeling that usd330 25 abit fake leh, their email all wrong one. wait you buy online liao no delivery
prolong used of the "manumatic" is not too 'healthy' for the auto tranny sweatdrop.gifsweatdrop.gifsweatdrop.gif Piggy Back ECU should be $1k++ if done in SG, over at JB, should be around RM1.3k.
mod your air intake to a coole air induction
change spark plugs to Iridium...
install a power boost valve
change your exhaust (extractor to muffler)
you will notice the diff..
the diff is diff that you dun need to convince yourself hard to believe...
u step on your gas, and you shall know
thks..
so far hv added a k&n drop-in filter..
hv the intention to do the following after 1st 5000 km svc which is next month...I believe after tat sure will void warranty if putting the add-ons and mod..
1. Add broquet & magnet
2. RMK voltage stabiliser or wat type of grounding
3. Want to put airmax 2 plus capsule (no sure good or not)
4. Improve brake control (dunno wat to do...using wat method??capsule again)
5. Lower springs..
Maybe don't need so much add-on or mod..need some advice..just want sometihng to improve performance..not vy concern about FC but also cannot be too bad...is it necessary to do these gag..
1. Add broquet & magnet. For the amt u'll be paying, i would advice against it.
2. RMK voltage stabiliser or wat type of grounding. Go for it.
3. Want to put airmax 2 plus capsule (no sure good or not). Go for it. Airmax ok, Capsule abit expensive 'cos urs a 2.3 need to get a bigger size one.
4. Improve brake control (dunno wat to do...using wat method??capsule again). Change brake pads and brake hoses (brake hose might cost abit). Most impt, your set of tyres.
5. Lower springs. Go for it. Check with Vtim, he might have some kang tau for you.
Wonder all these add-on or mods are LTA conpliance or not.. confused.gifYes, LTA compliance. (Warrenty issue you need to check with agent)
