RedM623 Neutral Newbie June 11, 2004 Share June 11, 2004 Hi bros, Read some thread on this but still cant get much info..Anyone can help on this? what can it really do? improve torque? FC or wat? where to install? heard ultramax but cant find the details leh.. what's the est damage? any other gadgets required after installation? BTW, will the ECU data reset itself to factory specs after some time? Thks. ↡ Advertisement Link to post Share on other sites More sharing options...
Goodspeed Clutched June 11, 2004 Share June 11, 2004 my limited knowlegde say that it is just playing with the fuel ratio / air ratio. if u want powerful pick up then the computer bluff the ECU to be in rich mode... anyway no additional booaster or anything.. more of just a chipset like overclocking...(it is better to add more hosepower) my 2 cent worth Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 12, 2004 Share June 12, 2004 if your car is stock, don't bother....as the gain vs the cost is not justifiable.... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched June 14, 2004 Share June 14, 2004 What I noe factory stock ECU is tuned for stock performance, may not necessary for better FC as newer cars chassis are getting heavier....... (oops there goes the power to kerb-weight ratio) Juz my $0.02. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 14, 2004 Share June 14, 2004 performance gains for sure. As for my conti car, ECU can only be resetted by mech. Basically it resets the adaptive driver profile and give better throttle response as well as performance. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie June 14, 2004 Share June 14, 2004 main purpose for me is to lean out the AF ratio, my tuner says i'm running too rich in mixture. Have gain some points from this but only marginal. Link to post Share on other sites More sharing options...
RedM623 Neutral Newbie June 15, 2004 Author Share June 15, 2004 thks bro, car is still quite stock except for a capsule and grounding which saw some improvement in low end torque.. thought putting a piggyback can better improve low end performance and a/f ratio.. when come to car technical issues, I must admit...me a dummy...saw some threads mentioned doing the exhaust can also increase hp..does it help? Link to post Share on other sites More sharing options...
RedM623 Neutral Newbie June 15, 2004 Author Share June 15, 2004 thks, IMO, the stock performance is not very good at low end...not looking for good FC but a smoother ride with ease of pick-up.. Yup..the ride is really heavy in weight and just thinking of putting some aftermart gadgets to boost the performance... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched June 15, 2004 Share June 15, 2004 (edited) Yep, we all suffer from "Need for Speed" syndrome........ Protege, Mz3 and M6 all are heavy chassis....... In the MCF meetups, Saaber (car guru) can give you many pointers. Edited June 15, 2004 by Normal_aspirated Link to post Share on other sites More sharing options...
Phochem Neutral Newbie June 15, 2004 Share June 15, 2004 haha... my car also. heavy with enormous body roll. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched June 15, 2004 Share June 15, 2004 Same here, back passengers got the roll-over when I do a tight turn......ever tot of lowering spring and anti-roll or sway bars? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 15, 2004 Share June 15, 2004 what car are you driving? Link to post Share on other sites More sharing options...
Phochem Neutral Newbie June 15, 2004 Share June 15, 2004 upgrade liao, coilovers lower by 30mm and a set of Whiteline ARBs (thicker than stock) both front and rear. i tink shld be my tyres lah, AspecDB sidewall softer somemore aspect ratio at 55. cant find any strut bars for my car. Link to post Share on other sites More sharing options...
RedM623 Neutral Newbie June 16, 2004 Author Share June 16, 2004 M6 2.3l... Not going for performance but would like a "better than stock ride" Hope can get advice from u as what N.A. mentioned...hehehe... ↡ Advertisement Link to post Share on other sites More sharing options...
How to Manage Manpower
DHL driver stops vehicle to piggyback elderly man across...
Managing Emotions
Managing Emotions
Giving away SwissTech Piggyback ECU for BMW 20/25/28i (N20)
How many politicians needed to manage the car population?
OBD tuning VS piggyback
V manage
V manage
Piggyback tuning in GT5.
