Ghostrider 3rd Gear July 8, 2004 Share July 8, 2004 Just change the rear muffler. Its not legal but usually TP will close one eye unless you put a hugh tip sporting on your exhaust pipe. That is a invitation for the TP for them to stop and book you. I was running with a cat back on my Civic....not loud unless I open up the revs....no problems with road blocks etc...the idea is...keep your car looking stock. If not you are just asking for the TP to come disturb you. Changing the rearbox alone would cost around 90-120. depending on what brand you take. The cheapest is still hotbits. Sounds a little bassy than stock exhaust...quite a nice note. ↡ Advertisement Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 8, 2004 Share July 8, 2004 I have no idea on this. But according to friends driving 4WD turbo monsters...its better than the Apexi one. But HKS stuffs should have some standard....just a matter on the pricing only. I love the HKS Super Drager....damn good exhaust and even more silent than my stock setup. But too pricy for me. 2K plus !! Link to post Share on other sites More sharing options...
Shoi Neutral Newbie July 8, 2004 Share July 8, 2004 (edited) Hi GHOSTRIDER, I want to change my CAT coverter, which one recommend to change the cat MAN exhaust or Fongkim? I'm driving G9 corolla Edited July 8, 2004 by Shoi Link to post Share on other sites More sharing options...
Orixy 2nd Gear July 8, 2004 Share July 8, 2004 Hi Ghostrider, can you enlighten me what is a "cat back exhaust"? Been seeing this term very often but never really know what it is. Thanx! :) Link to post Share on other sites More sharing options...
Tien Neutral Newbie July 9, 2004 Share July 9, 2004 Quote from Zrun: "An exhaust system is as follows: Header, catalytic converter, pipe 1, resonator, pipe 2, muffler. Usually, people do "cat(alytic converter) back" system, means everything after the cat is refined for max performance. A cheaper type is to do "axle back", means pipe 2 and muffler change. I believe all modification after the cat is legal, as they do not change emission, only the noise level." Link to post Share on other sites More sharing options...
Yansen Neutral Newbie July 9, 2004 Share July 9, 2004 i think to change the muffler would be illegal too Link to post Share on other sites More sharing options...
Orixy 2nd Gear July 9, 2004 Share July 9, 2004 Thanx for the great info!! Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear July 13, 2004 Share July 13, 2004 You want to change or remove ? Got those hi flow CAT convertors...but not cheap....cost around 1K plus. You can go to any exhaust shops....FK or MAN...Jeep Chee etc. Easy job...but its illegal hor...in case you dunno. Link to post Share on other sites More sharing options...
Shoi Neutral Newbie July 14, 2004 Share July 14, 2004 FK , Manz & JeepChee.Which have the good workmanship. Any advise from u? Mi just wan to change the dummy CAT only for G9. I ask Manz they charge ard $150 and FK charge ard $150-$180. Not sure JeepChee charge how much? Anyone noe? Link to post Share on other sites More sharing options...
Gabriel06 Clutched July 20, 2004 Share July 20, 2004 how much would changing the muffler be? and is it legal? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Carbon monoxide poisoning misdiagnosed as lymphoma
Advice on exhaust.
Advice on exhaust.
Ford invents retractable exhausts
Exhaust Welding job, MAN, Jeep Chee or Fong Kim
LTA Check - catalytic converter/exhaust
Anyone letting go HKS exhaust or FUJI with cert(ZC21)
NEA to lower vehicle noise levels from 2023
