Danapj Clutched July 6, 2004 Share July 6, 2004 Hi, Does installation of K & N filter voids the warranty? I am driving a new Altis and is there any modification to be made if I want to install K & N Filter. Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Orangie Neutral Newbie July 6, 2004 Share July 6, 2004 Should not be a problem.. but I changed to the stock filter everytime I goes to them for servicing just to prevent any un-necessary conflicts. Link to post Share on other sites More sharing options...
Danapj Clutched July 6, 2004 Author Share July 6, 2004 Didn't understand what you mean by changing to stock filter. You mean it is just a replacement without having to do any modification? Just put in the K&N filter into the cover and take it out and replace with normal filter during servicing? Link to post Share on other sites More sharing options...
Junjie 1st Gear July 6, 2004 Share July 6, 2004 Yes, it's just simply install by removing yr stock paper filter and drop in the K&N filter, no modification and no warranty void...just make sure u get the model suitable for yr car....check out the resorces thread, someone is selling it... Link to post Share on other sites More sharing options...
Orangie Neutral Newbie July 6, 2004 Share July 6, 2004 As what JunJie had explain. If you want to confirm whether BM voids your warranty for using aftermarket products, its best it come from the horses mouth. Link to post Share on other sites More sharing options...
Danapj Clutched July 6, 2004 Author Share July 6, 2004 Hi Thanks for all the help. Appreciate it. Will check with BM to see if warranty will be void. Link to post Share on other sites More sharing options...
Orangie Neutral Newbie July 6, 2004 Share July 6, 2004 Unable to help... feel like the ms hor ↡ Advertisement Link to post Share on other sites More sharing options...
Air Purifier Discussion - tips and info
DIY engine oil change
Recommendation for water filter
Dyson Zone, the real deal or has April fool's day come early?
Replacing fuel filter
TRD Engine Air Filter
More frequent filter and engine oil change due to haze
