Hoppe Clutched August 16, 2004 Share August 16, 2004 hehe...charade thread became Aveo chit-chat thread. :) come on, guys...let's be considerate lah. Xiong asking how to overcome overheat and u guys used his thread to chit-chat. ↡ Advertisement Link to post Share on other sites More sharing options...
Lordzen Neutral Newbie August 16, 2004 Share August 16, 2004 Bro'... where did you get the idea that my posting is merely chit-chat ? Since Xiong ask how to overcome overheat, i merely asked him to get his mech to do a pressure check on his radiator, which might be the cause of coolent leak which will also result in overheat problem mah. Like that you also consider chit-chat ??? Link to post Share on other sites More sharing options...
Hoppe Clutched August 16, 2004 Share August 16, 2004 (edited) pai seh not supposed to be addressing the reply to you, but to the posters (Lukie, Ah Liew) before you lah. Peace! Edited August 16, 2004 by Hoppe Link to post Share on other sites More sharing options...
Lordzen Neutral Newbie August 16, 2004 Share August 16, 2004 No problem bro' .. tot' you addressing the posting to me mah. ;0) Peace too ! Link to post Share on other sites More sharing options...
Turismo Neutral Newbie August 16, 2004 Share August 16, 2004 Hi Xiong5182, I used to drive a charade too. Have encounter similar problem as u. To solve the problem my mechnic do some tweak on the radiator fan. The fan normally kick in when the car temp. reach certain height, however after the tweaking the fan is on the moment the engine is started. However you will lose a bit of power....... Link to post Share on other sites More sharing options...
Hoppe Clutched August 16, 2004 Share August 16, 2004 it's definitely either the fan or water "leakage". Go check the fan. (Open up the bonnet, let the engine run till hot and rev the accelerate.. if I am correct, the fan should kick in , ie on and off depending on the temp). And investigate for leakages. Older cars (like my Swift) tends to have worn hoses. Very cheap to change. Link to post Share on other sites More sharing options...
Lukie102 Clutched August 17, 2004 Share August 17, 2004 hehe...charade thread became Aveo chit-chat thread. :)come on, guys...let's be considerate lah. Xiong asking how to overcome overheat and u guys used his thread to chit-chat. he PMed me liao. Have asked him to check with my mech. Anyway, did he reply to further postings?? Link to post Share on other sites More sharing options...
Lukie102 Clutched August 17, 2004 Share August 17, 2004 dropped by petrol station bought some Mr Clean MF cloth, 1 polishing cloth and a sponge(Mr Clean too i think) wax havent oops...kenna complained liao. talk to you on fri meet-ups Link to post Share on other sites More sharing options...
Lukie102 Clutched August 17, 2004 Share August 17, 2004 i think it is not advisable to on the fan the moment the engine is started. it does not allow the engine to heat up to its temp to perform Link to post Share on other sites More sharing options...
Hkarwai Neutral Newbie June 18, 2005 Share June 18, 2005 I just bought a 92 charade.. would like to know where to get the spare parts. Checked at waterloo st. very exp. readiator rubber hose original cost ard $30 each... any good shop tat sell original and yet cheap? Thanks. Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 19, 2005 Share June 19, 2005 ok got to change if radiator is spoil... so about how much will it cost to change a radiator??? pls advise... i changed my radiator for $100 bucks Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 19, 2005 Share June 19, 2005 radiator fan working and there's no leakage anywhere... wat else could have happen?? if the radiator fan working (properly i assume) and no leakage, then check temp sensor, temp sensor housing and radiator hoses Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 19, 2005 Share June 19, 2005 (edited) hehe...charade thread became Aveo chit-chat thread. :) come on, guys...let's be considerate lah. Xiong asking how to overcome overheat and u guys used his thread to chit-chat. Edited June 19, 2005 by Xtraun Link to post Share on other sites More sharing options...
Mivec9 1st Gear June 19, 2005 Share June 19, 2005 Bro'... where did you get the idea that my posting is merely chit-chat ? Since Xiong ask how to overcome overheat, i merely asked him to get his mech to do a pressure check on his radiator, which might be the cause of coolent leak which will also result in overheat problem mah. Like that you also consider chit-chat ??? not referring u lar... Link to post Share on other sites More sharing options...
Hkarwai Neutral Newbie September 27, 2005 Share September 27, 2005 Brand new? Original? Where? Thanks Link to post Share on other sites More sharing options...
Mivec9 1st Gear September 27, 2005 Share September 27, 2005 hi bro kkarwai, mine is recon...did at sin min autocare level 4, think is xenga engineering (the workshop is opp the star auto office). look for ah leong ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
Citroen C4 1.2 Sensor & Display
