Ghost Neutral Newbie December 18, 2004 Share December 18, 2004 need some help from the old bird here.. Presently my HU is the kenwood KDC-MP858 (link below) http://www.kenwoodaudio.com/common/prod.as...C-MP858&zone=sg wanted to know, my HU hv 2 preout, mean i can connect 2 amp using the 2 preout? ↡ Advertisement Link to post Share on other sites More sharing options...
Redliner_sg Neutral Newbie December 20, 2004 Share December 20, 2004 yes Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 20, 2004 Author Share December 20, 2004 thx .. BTW, i can do the following RCA from HU --> 2 channel amp --> 2 channel line out --> Y connector --> 4 cables to another 4 channel amp?? sorry for my newbie question.. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear December 21, 2004 Share December 21, 2004 (edited) Bro, why? RCA from HU --> 2 channel amp --> 2 channel line out --> Y connector --> 4 cables to another 4 channel amp?? Edited December 21, 2004 by Gadgeter Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 21, 2004 Author Share December 21, 2004 paiseh bro, i also blur liao... i think i know the way to connect liao.. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 21, 2004 Share December 21, 2004 this configuration might damage your amps. [reply] RCA from HU --> 2 channel amp --> 2 channel line out --> Y connector --> 4 cables to another 4 channel amp?? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear December 21, 2004 Share December 21, 2004 maybe can arrange to meet over the weekend to do it? or evening? Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 21, 2004 Author Share December 21, 2004 if i can;t make it then i call u lor .. but i think i figure it out since my HU hv 2 preout.. 1 to 2 channel , another to 4 channel.. btw, my HU preout stated 1 is front and 1 is rear... so wat tt's means Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear December 21, 2004 Share December 21, 2004 hmmm... then the setup will be: 1 preout (front) - use a 1-to-2 rca connector then join the 4 channel amp. 1 preout (rear) - use a 1-to-2 rca connector then join the 4 channel amp. must really look at your user manual liao. Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 21, 2004 Author Share December 21, 2004 blur liao blur liao.... my HU hv 2 set of pre out to RCA ah.. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 21, 2004 Share December 21, 2004 looks like the amp is a mono-block ? only 1 RCA per channel...no left or right ah... Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 21, 2004 Share December 21, 2004 hi, perhaps if you can post a pic of the rear panel, alot of us can help.. Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 21, 2004 Author Share December 21, 2004 Er.. the link in the first post can?? i still haven;t take out the HU leh.. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 21, 2004 Share December 21, 2004 sorry, the link does not say much. usually you can connect the pre-out to line-in of the amp. by looking at the rear of your HU, you should see Left and Right channels for both the front and rear. The RCA are colour coded for your reference..Right = RED, Left = White. Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 21, 2004 Author Share December 21, 2004 hmmm, maybe later i take a pic of the manual... Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 21, 2004 Share December 21, 2004 (edited) your present HU has 50W... into 4 ch. are you intending to connect to another amp to drive the speakers ? If yes, then your amp should be 80W per channel or more, else it would be a waste to not use your current HU. Usually 4 channel means 2* front and 2 * rear. from the description, looks like your rear preouts can be configured to a sub woofer, using the Y-connector..2 -to- 1 Edited December 21, 2004 by Ace_t Link to post Share on other sites More sharing options...
Ghost Neutral Newbie December 21, 2004 Author Share December 21, 2004 I will be using a lanzar 4 channel amp and bridge to drive the front CDT. while the back i think using the HU can liao.. The link to the amp: http://www.lanzar.com/itempage.asp?MODEL=HTG414 Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie December 21, 2004 Share December 21, 2004 looks like you have to bridge the Lanzar amps to achieve 300W per channel. BTW, your Lanzar is rated at 75W RMS... pls check that your Kenwood is not rated 50W RMS... coz then it would have not much effect on the power output. ie you can just use your HU to drive the speakers. ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
RAM/MicroSD issues
RAM/MicroSD issues
