Ebos Neutral Newbie January 13, 2005 Share January 13, 2005 Anyone knows the offical website for the Monster air charger? Thanks. :) ↡ Advertisement Link to post Share on other sites More sharing options...
Lawrenceloy Neutral Newbie January 13, 2005 Share January 13, 2005 What is it huh? Do what one? Link to post Share on other sites More sharing options...
Hattee Neutral Newbie January 15, 2005 Share January 15, 2005 Aiyah. Nothing high tech for air charger like Monster and Capsule. Some cars already have brake boost cylinder as added vacuum reservoir. The extra vacuum capacity does take in more air and allows stronger braking. Can also use goonie kong if doesn't collapse lah. Link to post Share on other sites More sharing options...
Fuzzylogic 2nd Gear January 15, 2005 Share January 15, 2005 I currently haf it fitted also the brake booster vacuum line to the manifold. Saw some pics of pple installing it from the enginer breather to the inlet of the intake hose. Which is preferable? Link to post Share on other sites More sharing options...
Phochem Neutral Newbie January 16, 2005 Share January 16, 2005 u mean the frm PCV valve to the side of the intake hose aft the air filter izzit? Link to post Share on other sites More sharing options...
Hattee Neutral Newbie January 16, 2005 Share January 16, 2005 Both should work. Better braking if at brake line. Link to post Share on other sites More sharing options...
Fuzzylogic 2nd Gear January 16, 2005 Share January 16, 2005 Yep, that's wat i meant. Saw some pple installing it that way. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie January 16, 2005 Share January 16, 2005 Hmm... same way as to connecting an oil catch tank???.... Link to post Share on other sites More sharing options...
Fuzzylogic 2nd Gear January 16, 2005 Share January 16, 2005 Yep, that's wat I tot as well. So I'm not too sure how such a connection will give better performance. ↡ Advertisement Link to post Share on other sites More sharing options...
Dodge V8 muscle cars to die by 2024
Bugatti Chiron
Bugatti Chiron
Is Turbonator = Air Charger = E68??? (30% HP Gain!!!)
Where to buy CTEK battery charger in Singapore
Warning: Car charger with 2 USB and Cigarette Lighter
Pls share your experience with EPS Power Charger
Car Battery Charger
Car Battery Charger
Cigarette charger
Cigarette charger
