Octy
Secondhand
Just wanna ask u guys... Regarding our clutch gear. How often do we need to replace it? Can we pop the hood and look at the gear? In the first place... where is it? [sweatdrop]
To identify that you need to change it, you will feel the Clutch will slip very time you clutch in and a cranking noise will occur when a gear is engage. Furthermore, you will also feel there's a lack of power / response.
Normally, we call it Clutch Pressure Plate and Clutch Disc which have to change both of these to rectify this normal wear and tear maintenance.
Manual transmission oil will also needed to be change if possible at the sametime.
Edited by Skodarr
Normal driving shd lasts abt 6 yrs or so. Poor driver less than 1 year, careful driver maybe 8 yrs
the only thing i could DIY with regards to my car was my 1st ride. 1972" toyota celica. Everything can DIY cos pure mechanical car. My throttle leve broke and used a old metal hang, bend hear and there, then fix it. Use spring from 35c pen and fixed carburetor butterfly value thingy (cos the spring busted and throttle does not close after you release the accelerator.
Nowadays, got sensors every where and you'll need fancy jigs to hold things in place. One simple thing out of place and the whole ECU will execute a "blue screen of death".
Blue screen easy to clear... [scholar]
Just hold ctrl, alt and del. Or u could just press clutch, break and accelerator while switching off and switching on engine. [nod]
Sure can restart ECU... [sweatdrop][nosebleed]
[thumbsup] Better yet... During thunder storm, go to open area, hook a metal rod to the car and wire it to the ECU. Once lightning strike, ECU confirm plus guarantee plus chopp, no more blue screen...
Instead u'll get 50% increase in horse power... [jawdrop]
Edited by Secondhand
Dude,
Well put ..... [laugh][laugh] [laugh]typical IT man's comment !!
