Genie47 1st Gear April 12, 2005 Share April 12, 2005 I can do all these. Brake shoes? Easily DIY'd and you will find them pretty good. I seldom use my brakes. Brake fluid should be DOT 4. Can't find the nice ATE TYP 200. PS fluid can easily blast out with the turning steering wheel left right method after isolating the input line. Else, can use the cheap turkey baster method and do over 6mths . As for coolant change. I found out that is not the drain port. GMDAT cars have no drain ports with stopc0cks! Changing coolant is a very wet affair for GMDAT cars. The "drain" is the small tubing that is entering the expansion tank. You got to run the engine first to make it heat up and get the thermostat to open. Then isolate this coolant input line and rev engine to drain from there using the water pump to flush. Cannot let the reservoir dry up so another person has to top up the expansion tank with water. Coolant reservoir is 7L and calculated, you need 10L of DI water for the flush. Once the coolant coming out is clear, quickly top up with concentrated antifreeze (3L) then plug back the input line quickly when you finish pouring in the antifreeze. Sounds like fun, eh? I will post instructions and possibly video tape the event. ↡ Advertisement Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie April 12, 2005 Share April 12, 2005 Yah.. Just wank the god damm steering to the left and right to get all the stupid P/S oil out. Hmm w/o drain plug, then why dont you just un-hose the lower hose going into the engine and let all the stupid coolant drained out instead of removing the little hose to Reservior?? Topping up will be via expansion tank. How about that? Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2005 Share April 12, 2005 Cannot use that hose lah! You need to flush the old coolant out from the whole system. Using the same principle as the PS fluid change, you use the tube that connects to the expansion tank as the end point of the coolant system so you can flush everything out. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2005 Share April 12, 2005 Since it is so troublesome just to change. I'm thinking of using the Prestone 5/150 coolant. 5yrs or 150k miles no need to change. Link to post Share on other sites More sharing options...
Tien Neutral Newbie April 12, 2005 Share April 12, 2005 interesting discussion... after reading, i have this strong urge... this irresistable temptation.... to hand over the servicing of my car to the workshop Link to post Share on other sites More sharing options...
Bleu Neutral Newbie April 12, 2005 Share April 12, 2005 Blur sia... too chiam for me to understand...kekke Link to post Share on other sites More sharing options...
Ferris Neutral Newbie April 13, 2005 Share April 13, 2005 Catch no ball too... Go sleep better. Link to post Share on other sites More sharing options...
Bleu Neutral Newbie April 16, 2005 Share April 16, 2005 keke.... koon ↡ Advertisement Link to post Share on other sites More sharing options...
Automakers Killing Touchscreens and Bringing Back Buttons
Toyota Harrier Auto transmission problem
Hard to engage in 1st gear after transmission oil change
What is the current Manual car selling in Singapore?
Mercedes Gear Shifter (Steering mounted)
Loud sound when engaging reverse gear (CVT)
Electronic gear
Electronic gear
