Nerd_on_wheels Neutral Newbie April 17, 2005 Share April 17, 2005 oooo, the website improved a lot since way back then when I saw it. The marketing improved a lot. But I guess at about a few thousand percent of profit vs minumum research, minimum material cost, its naturally can pump in more fund for the marketing department. ↡ Advertisement Link to post Share on other sites More sharing options...
Lordalfa Neutral Newbie April 17, 2005 Share April 17, 2005 Something like that blocking the air intake. Surbo will become SuckBo. Hokkien for Suck Nothing. Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 ouch.threw it in dustbin?you must be pretty pissed. Link to post Share on other sites More sharing options...
Julian Clutched April 17, 2005 Share April 17, 2005 Get a stock Turbo charge car, that is what i am going to do and no need to mod up car. I see some people mod their 1.3 with bodykits, air filter blah blah etc.... if car is 83hp, it will not be any faster even if u spend thousands... might as well get a t/c of similar capacity and u get 130hp, no need to mod at all.... Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 agree totally! Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 if product is good,why dun let people dyno? these addons don't show up much in dyno, probably 2bhp, not much to appreciate for those who drive performance car. Just better throttle response. Forced induction is the thing to go for.........if u want real power. Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 better trhottle response? not bad lah Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 (edited) do u know also, even light weight crank pulley doesn't show any power gain on dyno? just better throttle response. Doc genie had already explain why.....heehee. Edited April 17, 2005 by Normal_aspirated Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 knn.I changed crank pulley....no effect.only effect is th after-mkt one lighter that stock!!! Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 mine got effect, accelerator pedal now feel much lighter and better throttle response. Guess some cars behave differently. Link to post Share on other sites More sharing options...
Gnoikj Neutral Newbie April 17, 2005 Share April 17, 2005 hello ppl. newbie here. was browsing and saw this. actually i personally love the surbo. have try on both cars, manual and auto. 1st car(van) VW caddy petrol 1.6 manual. after installing single surbo. 1st gear = fuel cut (6k rpm) 2nd = fuel cut. 3rd already running at 120 to 130 km/h. fuel com? save when you rev. dunno why. tried bullying a lancer. he dunno can smell my smoke. kekekekekek. install twin surbo....not so good. good at hi end and lost low end. 2nd car (mazda 3) helps a million in low end. with the military tank body. consider very good liao. DIY CAI Box and install the surbo back? hmmmmm..... very good result. FC not much change but the pick up is better. installed a open pod. lost all low end. add in surbo again. low end was back. to bros out there, if you think surbo dun work maybe becoz theres a leak. ask that guy to fix it for you. sure to work. had intro a IST friend and he love his ride and a Caddy bro love his ride too. i personally give a very big . just my experience in testing out surbo. No leh...I check with all workshop contacts I know, they just shake head only and say that's a con job...Anyway, if ur van can get lancer to smell smoke, then you should be going way over the legal speed limit of a van (60/70?)..I din know vans can add things like this? Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 hello.when want to mod?!? must poison people around me liao Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 hmmm...shld I try? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 u mean install surbo? can save money DIY beer clones one......heeehee Link to post Share on other sites More sharing options...
Gnoikj Neutral Newbie April 17, 2005 Share April 17, 2005 haha...not yet lah...think will start off with struts and filter first... when I get some free time will call u out to check out your car... wait for my PM... Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 thot you said good... you meant crank pulley ah? Link to post Share on other sites More sharing options...
Accordvtec 1st Gear April 17, 2005 Author Share April 17, 2005 filter? do this lah... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 (edited) for japs car, light-weight crank pulley is a good investment. Dunno about conti, some not recommended. Though quite exp $270 from McWell, Fong Kim, ADM, etc. make sure is exactly same shape & size and made of aircraft type aluminium alloy. Edited April 17, 2005 by Normal_aspirated ↡ Advertisement Link to post Share on other sites More sharing options...
Surbo Turbo ?? try experience??
Twin surbo ..shud i or shudn't i
Surbo
Surbo
Surbo
Surbo
DIY CAI to replace surbo?
Surbo
Surbo
Surbo
Surbo
SURBO & Automatic cars
