Fortress Clutched October 10, 2005 Share October 10, 2005 (edited) Am quite sure a jack is part of your car accessories, and during a inspection, you need to have it. For different car , it differs, hence, when I purchase mine, I make sure that the car can be maintain easily. The car can still run on the battery for quite some distance, until it is flat, by then you can fix the alternator back to recharge it....sigh..we singaporean. Edited October 10, 2005 by Fortress ↡ Advertisement Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie October 10, 2005 Share October 10, 2005 hhmm... not too nice to name the place, .... but it's at bukit batok and it's one of the ws that opens on sundays lor.... now i just wanna get a trusty ws and get a second opinion.... i dun wanna somethng to go wrong or the cable melting.... Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 There's one lanky young mech who after installing new battery, (as my car engine died which driving and after off A/C, able to drive but showed low batt light) the low batt light still on. The hunky chap who always fix my car came along and brought tube like voltage instrument to measure. Think was only 12V. May need tow-truck in fact as no power, engine cannot keep up..lucky i was on the verge liao...save some tow charge and rush to simon So far, no intermittent failure of any kind...my alternator juz died. Only symptom was 2-3 weeks ago, the alarm auto unlock whenever i depress the brake (by rite is brake, it will lock door). After top up batt water, symptom solved. Thanks for your advise. I'll monitor mine in case similar sympton appears. Link to post Share on other sites More sharing options...
Stan10 Neutral Newbie October 10, 2005 Share October 10, 2005 Hi, i m having some sort of similiar problem. Idling was low, volt shows between 11 - 12 v @ nite when lights n air con switched on, and a click clock click clock sound coming from where the batt was. Mech told me it was insufficient air which cause low idling, but personally I feel it was the alternator... Yet to had it repaired cause feels like asking other workshop for opinion.. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 normally for me is if never spoil, dun change...heh heh... but i think wat ur mech said is correct since battery in good health, the only thing that affect the low voltage would be the alternator...which is run by the alternator belt. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 i dun think can diy for me, unless u r quite hands on ....i see them do, i also dun think i can make it. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 well for recon shd be around that price. maybe u juz adjust idling higher...no need change alternator...waste $$ Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 actually i dun understand abt the extra cable....dun make sense leh Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 no worries. gd luck Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 u can drive to simon @ yew tee for 2nd opinion...feel either ur battery or alternator wanna "ki chia" liao Link to post Share on other sites More sharing options...
Stan10 Neutral Newbie October 10, 2005 Share October 10, 2005 Ummmm, me staying east leh, to yew tee too far leh... Got batt replace abt 6 mths ago, should be alrite, so my guess is alternator... Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie October 10, 2005 Share October 10, 2005 yah.... i have a feeling that the fault maybe the existing cable, so when he changed the alternator, and yet still not charging, so link a cable direct to the alternator lor.... so i will go ask for a second opinion, then if it's really true, then i go talk to the ws again. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 if u off A/C, still have this prob?? If still have, maybe u need to adjust idling rpm to higher than what u have now. I guess u have less than 1000 idling rpm. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 think best get a 2nd opinion. The 2nd cable seems not logical. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie October 10, 2005 Share October 10, 2005 yah lor.... i dun understand the 2nd cable.... Any good and trusty ws to recommend?? Link to post Share on other sites More sharing options...
Stan10 Neutral Newbie October 10, 2005 Share October 10, 2005 Off A/C no problem liao as rpm oredi adjusted to over 1000, but ixit alternator?? Got to get it replace asap, scared half way breakdown le... Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 the only one i kw is quite gd is simon @ yew tee Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 cheaper way is adjust rpm higher lor..but think ur alternator also not in gd condition. Best is to change it. ↡ Advertisement Link to post Share on other sites More sharing options...
Alternator fail
Alternator fail
Changing Timing/Alternator/Aircon Belt
Any workshop/individuals out there who can repair alternator?
Alternator Bearing
Alternator Bearing
Alternator - How to tell if it is kapoot!!!???
When Alternator is spoilt, what will be affected?
Changing Alternator
Changing Alternator
Battery problem? Or Alternator?
