Fortress Clutched October 10, 2005 Share October 10, 2005 What i did was to use a smaller pulley on the alternator to provide a higher voltage charging and current supply. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 10, 2005 Share October 10, 2005 (edited) One end of the cable is bolted on to the alternator "B" terminal and the other end to the battery positive terminal. The cable maybe heavy corrosed inside and therefore cause high resistance to the flow of electrons - for auto electrician they normall take volt drop reading from on end of the cable to the other end while the alternator is running. If the DC volt reading is more than 0.5 volt that means the cable is resitance is high and has to be replace. Edited October 10, 2005 by Yeobh Link to post Share on other sites More sharing options...
Stan10 Neutral Newbie October 10, 2005 Share October 10, 2005 Not sure how to do it le Link to post Share on other sites More sharing options...
Fortress Clutched October 10, 2005 Share October 10, 2005 there is a belt that turns the alternation through a pulley attached to the alternator. eg, the pulley diameter is 10cm, then change it to about 8 cm, thus making the alternator runs a little faster. Hope I have clarify your query. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie October 10, 2005 Share October 10, 2005 ok.... cool. so it's not wrong that they connect another cable to the battery lor. but the cable is a those rather thin type, way smaller than the original one. is it ok? will it melt? can it tahan? Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 10, 2005 Share October 10, 2005 No problem , if I read it right what the mech is trying to do is to provide an altenrative route for the electrons to flow from alternator to battery. When the alternator is running at 2,500rpm it should produce 14.2 volt and by the time it reaches the battery the voltage will drop to 13.8volt due to the cable internal resistance to electrons flow. So if the existing cable produces very high resistance the voltage drop can be much higher than the aceeptable 0.5 volt. resulting in heat buit-up in the cable and lower voltage going into the battery therefore less electrons will be "push" into the battery plates. Overtime the battery will always be undercharged and with prolong use will cause serious damage to the battery plates resulting in sudden battery failure. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie October 10, 2005 Share October 10, 2005 bro YEOBH, you can always answer a lot of my question and blurness..... so in you opinion, should i go and get the cable change to a thicker one? now when i start car, it reads 14.0 to 14.1. then when moving, suka suka 13.5 then sometimes 13.9 or 14.0 (that under same driving condition) Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 bro yeobh, u never fail to impress me with ur good knowledge Link to post Share on other sites More sharing options...
Yc86 Clutched October 10, 2005 Share October 10, 2005 Hi Xtraun today went down to simon there to check it out and it turns out its just like what stan said.. something to do with the air. a vacuum intake that should have been plugged was opened. he also said the previous owner anyhow connect the piping and if have time go down again to re-do it. or can take a look at another swift and follow the same connections. service was not bad.. n he nv charge me for the rubber plug and service like your if not spoil then don't change idea.. lolx Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 10, 2005 Share October 10, 2005 Yap, that place pricing is reasonable and honest. I go there for my routine servicing and repair. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 10, 2005 Share October 10, 2005 Not necessary. The readings you mentioned are taken at the battery terminals,or via volt meter - they will not be able to show the true ouput form the alternator. Also the reading will fluctuate due to engine speed and load ( electrical demand from yr air con , ICE, etc) variation. At battery terminal 13.9volt will be good enough. Link to post Share on other sites More sharing options...
Yeobh 4th Gear October 10, 2005 Share October 10, 2005 Thax for the compilment. What I have earlier explain are all basic auto electrical theory nothing special like rocket science. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie October 10, 2005 Share October 10, 2005 (edited) the readings i mention are from my volt meter. ok. so i dun have to go check and change the cable to a thicker one then lor. and with the knowledge you shared, i think i will just stick to what i have for now. i was very worry that the cable may not take it and burn and/or melt before. Thanks bro Yeobh!!! Edited October 10, 2005 by FGY7022 Link to post Share on other sites More sharing options...
Yc86 Clutched October 10, 2005 Share October 10, 2005 are you driving a swiftie too? i think they're friendly too.. but they don't seem very specialised with the swift. more of general repairs? Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 great to hear u went down to simon and finally solved ur prob! So far think simon ok, as compared to my previous mech from sin ming. Fast and good. Agree....anything not spoilt, dun change.. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 i'm already addicted to simon....... Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 hee..but not everyone understand the basic...like me...so it's good to have someone like u to enlighten us Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 10, 2005 Share October 10, 2005 they are more generalised repair/spare shop. Octopus driving a corolla...and he's the one who recommend me to simon ↡ Advertisement Link to post Share on other sites More sharing options...
Alternator fail
Alternator fail
Changing Timing/Alternator/Aircon Belt
Any workshop/individuals out there who can repair alternator?
Alternator Bearing
Alternator Bearing
Alternator - How to tell if it is kapoot!!!???
When Alternator is spoilt, what will be affected?
Changing Alternator
Changing Alternator
Battery problem? Or Alternator?
