Toyota Sera Gullwing
Serag15
Any views on tis car.....I'm quite interested in getting it
1 available at sgcarmart for about $35k...nice car but dont tink tat its worth at that price..
Edited by Serag15
I went to see this car. The tappet has something wrong. They dont allow u to rev. Also, the customised job is not done nicely. U can see the moulding like cement plaster at the front. Rear is leaking H2O. If u can do it up esp the wiring etc, meaning spend some $$, it will be fine. Else, I think go for a Paseo.
Cheers.
Very nice.
Also, the car is so beautifully done up.
Sure to make heads turn...
Headlamps and taillamps are so nice [flowerface]
I am falling in love with this Babe.
I felt that any mechanical problems
can be repaired..
It is a Toyota.
Its actually a Toyota Tercel powered by a 5E-FHE engine and has gullwing doors. Great looker but not great on performance. The 5E-FHE engine is a high compression version of the 5E-FE. Performance wise, it is not great.
Most UK owners chucked the engine for a 4E-FTE found in the EP82 and EP91 Starlet/Glanza. Adventurous ones mated the top block of the 4E-FTE with the bottom end of the 5E-FHE engine. What seperates the two engines is just stroke length. Yes that is how Toyota cheats in the displacement game. Both engines have the same bore length but the 5E has a longer stroke length.
Similarly, that is how the local 1.6L 4A-FE Corollas are seperated from the US muscular brothers with a 1.8L 7A-FE engine. This also explains why some seemingly more powerful EFI 1.6L cars get smoked by miniscule Starlets equipped with a dirty carbureted engine. Savvy Starlet owners know how to perform voodoo. sly.gif
There are pros and cons to longer stroke length but we will leave that to the Performance folder.
To answer your question properly... its (the paseo) a 2 door corolla.
If the sera has tappets problem, it means that air has gotten into the engine hydralics. If it was me, i would just get a reconditioned head from a corolla and swap them around.
Edit:
Genie is pretty much right. Btw, genie, are u going to start talking abt bore to stroke ratios and how they work soon? I think most ppl here would faint halfway...
With the Sera, the rolla head would be better as the intake cams are slightly more aggressive than the tercel cams.
Edited by Elfenstar
Not Corolla lah! The designation is not AE. Neither does it qualify for Starlet because it is not EP. But it is Tercel with EL. But it is known that Toyota tries to market their cars by initially tying the name to the Corolla like Corolla Tercel when it first came out and later they dropped the Corolla. The are doing the same thing with the Altis.
Toyota has always been easy to figure out. First letter basically denotes the engine. If start with "A" means has A engine like your Trueno 4A-GE.
"E" is the designation belonging to Corollas. So if you see EE90. Quite obvious it is the E engine Corolla and most likely the Corolla XL with the carburetted 2E engine which still hangs around on our roads.
The number is just the model number. So AE100 is later than AE92. That's it!
