Andrewkb Neutral Newbie January 18, 2003 Share January 18, 2003 I've heard of placing magnet on the air intake ... Wat's the rational in placing on the air intake pipe ? My perception is that air intake pipe is thick and high flow rate ... as such, a small magnet (no matter how strong) cannot cover the whole intake pipe in full ... Placing 2 magnets at opposite ends is also touch, since it will be difficult to mount it on the "far, unseen, bottom" end of the pipe. Can someone please help enlighten ? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Chris_ck Neutral Newbie January 18, 2003 Share January 18, 2003 That's a first for me . Maybe cool has heard of it Link to post Share on other sites More sharing options...
Madarmour Neutral Newbie January 19, 2003 Share January 19, 2003 How about putting 20 magnets? Would that be strong enough? Link to post Share on other sites More sharing options...
Lester Neutral Newbie January 19, 2003 Share January 19, 2003 Hi there AndrewKB Air intake magnets are larger in surface area. They cover almost the circumference of the intake tube. And they are ususally very costly. There are other ways to enhance air intake then that. Here's a better author than me to explain things: http://www.fut.es/~sje/mag_fuel.htm Regards Lester Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie January 19, 2003 Author Share January 19, 2003 Thanks .. thut it's the same magnet ... BTW, the website not accessible leh Link to post Share on other sites More sharing options...
Lester Neutral Newbie January 19, 2003 Share January 19, 2003 Hi there AndrewKB I din have any problem. Try again? Any others having problem? Regards Lester Link to post Share on other sites More sharing options...
Jermy Clutched January 19, 2003 Share January 19, 2003 Nope...i have no probs.. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie January 19, 2003 Author Share January 19, 2003 Can liao ... Link to post Share on other sites More sharing options...
Cool Neutral Newbie January 19, 2003 Share January 19, 2003 (edited) Me and Turbobrick has explored this before.. basically, air travel too fast to be magnetise and since it intangable. Theoritically, if you "north" the air, then the fuel must be "south". For both to attract. The magnets 1st Version Turbobrick did was base on this principle. A simple test would be getting harddisk magnet.. put it around your air-intake hose, and give a try. I have tried this before (removing grounding and apollo).. no impact. If I did work for me, I would have made the magnets and sold it to you all .. cheers... Edited January 19, 2003 by Cool Link to post Share on other sites More sharing options...
Lester Neutral Newbie January 19, 2003 Share January 19, 2003 Hi there Cool HD magnets are too weak to input any effect on the air velocity. You need one with at least 800gauss to make this work and this is only for a cross sectional area of 1 3/4 inches hose. Ferrite magnets are ideal in this case. Ferrite costs more than Neodynium, thus this is an option which renders uneconomical. Not that it doesn't work. Regards Lester ↡ Advertisement Link to post Share on other sites More sharing options...
Meguiar's Water Magnet MF drying towel
Intake manifold Gasket mod
Wtb: Audi A3 2010 windows magnet shield
Audi A3 2010 window magnet shield
APEXi open pod power intake kit from ARK Motorsports
Intake temperature
Intake temperature
How to aim spark plug towards the intake side of the cylinder head
