Steady Neutral Newbie September 18, 2005 Share September 18, 2005 Just a precautionary to others: Any of you had installled ATF cooler from Servo? Better go check the existing pipes that they've used. Why? Bcos mine was installed using a low pressure, fuel grade, rubber pipe. And it burst during the weekend, Friday night some more! Had to tow it to workshop and wasted my weekend night out! The ATF fluid had decorated all of my engine interior, and after spending 3/4 of the day changing to 400psi-grade pipe, found out that my main radiator fan had died as well.....damaged by the ATF fluid I guessed. So no choice, had to change that too. Better go check that pipe immediately! ↡ Advertisement Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie September 18, 2005 Share September 18, 2005 Woo, sorry to hear this bro ... I believe the pipe is bundle with the ATF Kit ... I also think that you are the first with this problem bro ... Should tell Servo to notify the supplier ... Link to post Share on other sites More sharing options...
Lightspeed Clutched September 18, 2005 Share September 18, 2005 Amos... any ideas if we can get our hands on steel braided hoses for the ATF cooler? Much better than the rubber hoses Link to post Share on other sites More sharing options...
Moeykf Neutral Newbie September 19, 2005 Share September 19, 2005 steel braided hoses more efficient for ur brakes hehe....atf hoses jus change higher pressure ones can liao Link to post Share on other sites More sharing options...
Steady Neutral Newbie September 19, 2005 Author Share September 19, 2005 Nah, I think they too busy to listen to me anyway. But I will try, so that other bro will not have the same problem. BTW, any chance I can claim for them ...... tough luck huh. Link to post Share on other sites More sharing options...
Lightspeed Clutched September 19, 2005 Share September 19, 2005 I got mine fixed at Servo also... dunno what hoses are they... any idea on these high pressure hoses? How muchie? Link to post Share on other sites More sharing options...
Steady Neutral Newbie September 19, 2005 Author Share September 19, 2005 I retrofitted mine at CAG auto. They bought extra length of hoses when they were doing up my car. Can try there. I'm going back there end of the month again for tuning and servicing. Link to post Share on other sites More sharing options...
Lightspeed Clutched September 19, 2005 Share September 19, 2005 CAG? Getting good response from alot of forummers... my trip there was scary though... left as soon as I could Link to post Share on other sites More sharing options...
Steady Neutral Newbie September 19, 2005 Author Share September 19, 2005 Ah well, it is quite a new workshop and they have only 1 experience mechanic. Link to post Share on other sites More sharing options...
Volk74 Neutral Newbie September 19, 2005 Share September 19, 2005 Was thinking to fix previously...but held back due to $$... Will take note next time...so must inform the installer that must be 400-psi grade pipe..right? Link to post Share on other sites More sharing options...
Steady Neutral Newbie September 19, 2005 Author Share September 19, 2005 Not too sure about the psi grade, but that's what was recommended by the workshop. Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie September 19, 2005 Share September 19, 2005 (edited) Amos... any ideas if we can get our hands on steel braided hoses for the ATF cooler? Much better than the rubber hoses Yes, agreed... Steel Braided Hoses are meant for high pressure and temperature purposes... AND WILL NOT LEAK OR BURST ... I done up my Engine Oil Cooler with it which cost me $920.00 ... But it's problem free until today about a year liow ... Yes, can customize but it will be extra cost to you ... If you are interested, you can let me know ... I can do it for you ... Edited September 19, 2005 by Skodarr Link to post Share on other sites More sharing options...
Lightspeed Clutched September 19, 2005 Share September 19, 2005 How much will it be? Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie September 19, 2005 Share September 19, 2005 Nah, I think they too busy to listen to me anyway. But I will try, so that other bro will not have the same problem. BTW, any chance I can claim for them ...... tough luck huh. Well, you can always talk to Dennis bro... I believe he will solve your problem... Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie September 19, 2005 Share September 19, 2005 The cost will determine the length and the adaptor used for the kit... You will require 2 pairs of hoses with similar length and 4 adaptors, 2 for the cooler and 2 for the ATF Transmission. Currently, are you on any ATF Cooler kit...? Link to post Share on other sites More sharing options...
Lightspeed Clutched September 19, 2005 Share September 19, 2005 Now using Hayden ATF Cooler.... got it fixed up at Servo several months ago Link to post Share on other sites More sharing options...
Skodarr Neutral Newbie September 19, 2005 Share September 19, 2005 Not sure what model you have fit on ... May be I can meet you up at Servo to find out and also fix up your Speedo Chrome Rings bro ... But no warranty ya ... Link to post Share on other sites More sharing options...
Lightspeed Clutched September 19, 2005 Share September 19, 2005 I'll be around Sin Ming area 11am+ tomorrow.... Maybe if you're nearby can take a look ↡ Advertisement Link to post Share on other sites More sharing options...
Is Singapore Safe From Earthquakes ?
Favourite Japanese Songs from 1980-90s
Yusheng from Singapore, Malaysia or China
How to trace owner from vehicle registration number?
Black flakes from washing machine
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
GSS 2021 join forces with Lazada
From India to S.Africa in an off-peak Hyundai Matrix
