Chewing_gum Neutral Newbie February 14, 2003 Share February 14, 2003 Hi Bros, I seems to have some brake problem,there is some weird sound coming from front brakes of my Mit. Chariot, but i have no problem in stopping my car.It just happens when that everytime i depress the brake pedals slightly to slow down the car.Hope u guys can heplpblush] ↡ Advertisement Link to post Share on other sites More sharing options...
Luke721 Neutral Newbie February 14, 2003 Share February 14, 2003 Ha-Lo, Can you elaborate more on the 'sound'? Is it as if something is knocking within the bonnet everytime you depress the brake to slow down? I guess if your chariot is still under warranty, better to send back to C & C and ask them to check properly - I guess that's what warranties are for , and the dealer should do a good job in trouble-shooting your prob for you Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 15, 2003 Share February 15, 2003 When was the last time you change your brake pad? Link to post Share on other sites More sharing options...
Chewing_gum Neutral Newbie February 15, 2003 Author Share February 15, 2003 not sure , but on my last servicing(Dec'02).Mechanic check no problem leh Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 15, 2003 Share February 15, 2003 Sometimes it is because for some brake pad when is wearing thin, there will be a thin metal strip rubbing the rotor to signal the end of pad life.... Happen only recently? or once in a while? Link to post Share on other sites More sharing options...
Phalanx Neutral Newbie February 15, 2003 Share February 15, 2003 You need to describe what kind of sound...high pitched whine 'eeeeee' or kinda like a knocking sound? Link to post Share on other sites More sharing options...
Blackford Neutral Newbie February 15, 2003 Share February 15, 2003 Sounds like worn out brake pad... Link to post Share on other sites More sharing options...
Blackford Neutral Newbie February 15, 2003 Share February 15, 2003 How long do you have the car... Brake Pad should change after 3 years.. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie February 18, 2003 Share February 18, 2003 it may bedding not good enough. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 18, 2003 Share February 18, 2003 Could be.... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie February 18, 2003 Share February 18, 2003 few problems lah 1) Brake pads gonez 2) Brake disk not flat already, uneveness causes the screeching sound 3) Too much rust and brake powder on your brakes Any other problems others can think off? u probably need to troubleshoot. get your mech to do it. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie February 18, 2003 Share February 18, 2003 #3 can skipped it since he mentioned that changed brake on last Dec. Link to post Share on other sites More sharing options...
Chewing_gum Neutral Newbie February 18, 2003 Author Share February 18, 2003 wah like that may be better go for brakes check ASAP ↡ Advertisement Link to post Share on other sites More sharing options...
MOM help FTs look for jobs ?
FORCE Big Brake Kit promotional Price
