Kaer Neutral Newbie April 28, 2007 Share April 28, 2007 (edited) whoa you really OT... but that day i was in the carpark, also this guy suddenly moved off and i gota cham brake. he still can tio me somore. nbz anyway, my 5th gear will come on only when am at 80 or 90. Edited April 28, 2007 by Kaer ↡ Advertisement Link to post Share on other sites More sharing options...
Les548 Neutral Newbie April 28, 2007 Share April 28, 2007 how abt free the gear at 80km till stop when reaching a traffic light. will this caurse any harm ? Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear April 28, 2007 Share April 28, 2007 (edited) Never coast on neutral. It's a safety hazard and also does not really save petrol as engine is idling anyway. Just keep on highest gear. As for the main question, always try to upshift in the power band of your engine. If shifting is done prematurely, not only does it cause engine wear, it is also counter to the thought of "saving fuel". Your engine is way too low rev to generate enough torque, hence the juddering and the engine struggling. End up stepping on more gas to move. Edited April 28, 2007 by Vblaster_w211 Link to post Share on other sites More sharing options...
Kalaplus Neutral Newbie April 28, 2007 Share April 28, 2007 u cant put neutral than turn ur car, if speed too high, ur car will skid. u must down shift before u turn. when to downshift? what u doing? doing normal turn or running with someone? if normal driving, just brake & downshift & turn loh. if runing than u must use heal toe. Link to post Share on other sites More sharing options...
Kalaplus Neutral Newbie April 28, 2007 Share April 28, 2007 at 80km/h u free gear, if u suddenly do a sharp turn to avoid something, ur car will skid badly. dun ever free gear, it very dangerous. Link to post Share on other sites More sharing options...
Godibado Neutral Newbie April 28, 2007 Share April 28, 2007 seriously ahz? wah i tot can save fuel doing that.. better stop! Link to post Share on other sites More sharing options...
Kaer Neutral Newbie April 28, 2007 Share April 28, 2007 I dont do that. I will slow down and downshift to 3rd and stop then neutral. Link to post Share on other sites More sharing options...
Godspeed Neutral Newbie April 28, 2007 Share April 28, 2007 it will eat more fuel Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear April 28, 2007 Share April 28, 2007 (edited) Most of it has been said, there is some hearsay but to sum it up: 1) Increase in FC. 2) Increase in load on the engine and drivetrain The clutch will be fine. Its wear-rate is determined by how much slipping there is (i.e. faster gear changes reduce wear- but faster changes also cause more shock to the drivetrain) There is an optimal range to upshift. It varies from car to car. For FC, anywhere between 2.5k to 3.5k rpm. There is also an optimal range to downshift. Once again it varies, but the range is smaller than upshifting. Generally between 2.5k to 3k rpm. In case anyone is curious, you're stressing the engine much much more by upshifting early but there is less stress on the engine by downshifting early than any sort of acceleration (yes even less than if your 80 yr old grandma is accelerating). Edited April 28, 2007 by Elfenstar Link to post Share on other sites More sharing options...
Eaststargrouper 1st Gear April 28, 2007 Share April 28, 2007 Hi guys I have a friend, who has the habit of changing gear before the car reaches enough rpm. It will cause a slowdown in picking up speed in the next speed in the next gear. In fact, for every gear, he does the same thing. When he reaches only 50, he changes gear to the 5th. Apart from increasing the FC, what will other impact be? A faster wearing out of cluth disc? Any advice? Up-shifting mostly causes less wear and damange to cluth disc than forced down-shift. The impact of "premature shifting" may just be a feel of lack of power. Link to post Share on other sites More sharing options...
Ken_au Neutral Newbie April 28, 2007 Share April 28, 2007 bro teach me how to heel-toe leh... Link to post Share on other sites More sharing options...
Alanswan Neutral Newbie April 28, 2007 Share April 28, 2007 Never could understand the synchromesh thingy... But wanna ask, if got synchromesh, any adverse effects to double-clutching anyway? Kinda got into the habit of doing that after watching too much Initial D... Link to post Share on other sites More sharing options...
Wilb Clutched April 28, 2007 Share April 28, 2007 Lol heel toe, cornering at racing track issit. Link to post Share on other sites More sharing options...
Vamping Neutral Newbie April 28, 2007 Share April 28, 2007 u cant put neutral than turn ur car, if speed too high, ur car will skid. u must down shift before u turn. when to downshift? what u doing? doing normal turn or running with someone? if normal driving, just brake & downshift & turn loh. if runing than u must use heal toe. wad are the best kph to do downshift coz its very diff to feel and must see if got car or ppl walking in front.. any tip? Link to post Share on other sites More sharing options...
Icekitten Clutched April 28, 2007 Share April 28, 2007 I thought 5th gear can't be engaged unless you travel over 80km/h. Something to do with the synchromesh. Cannot be. I can engage 5th at 60+kmh without effort. But I usually do it at ard 72kmh la. Maybe it only applies to some cars. But if it's a normal saloon, the FC must be pretty high for that car since 80kmh is around 3k rpm at 4th gear. Link to post Share on other sites More sharing options...
Kalaplus Neutral Newbie April 28, 2007 Share April 28, 2007 http://www.edmunds.com/ownership/howto/art...92/article.html here got teach Link to post Share on other sites More sharing options...
Kalaplus Neutral Newbie April 28, 2007 Share April 28, 2007 if never pratice everyday, how u going to do it on track? it is not something easy to learn. Link to post Share on other sites More sharing options...
Kalaplus Neutral Newbie April 28, 2007 Share April 28, 2007 for normal driving, u brake till u know that speed not suitable for this gear anymore than downshift loh. i dun think got such thing as best km/h to shift. ↡ Advertisement Link to post Share on other sites More sharing options...
Paddle shifters - fixed to wheel or column?
Premature ejaculation hits one in three S'pore men
And so Nas Daily decides to shift to SG after all lor
Toyota Harrier Auto transmission problem
Hard to engage in 1st gear after transmission oil change
What is the current Manual car selling in Singapore?
Mercedes Gear Shifter (Steering mounted)
