Sofarsogood 1st Gear April 15, 2006 Share April 15, 2006 Was doing some Diy in my engine bay and discovered the (-ve) cable from my Raizin disconnected from the battery!! Quickly fixed it back. Got shocked a bit by the sparks that flew when I touch the cable to the (-ve) terminal of battery. Anyway, I think it must have been the time when the AA engineer changed my battery, and left the Raizin disconnected. ↡ Advertisement Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie April 15, 2006 Share April 15, 2006 Nice information ..to go with that what did you have for dinner? Link to post Share on other sites More sharing options...
Sofarsogood 1st Gear April 16, 2006 Author Share April 16, 2006 Ha ha... I actually wanted to ask whether the sparks were normal... guess in a haste, that was left out. BTW, i had fried rice for dinner. Link to post Share on other sites More sharing options...
Kcseah Neutral Newbie April 16, 2006 Share April 16, 2006 Did you do it when the engine is on ?? if yes,that maybe the case the sparks comes from. Anyway, if you can start your car and everything is working fine, should be ok. Link to post Share on other sites More sharing options...
Jamesgetz 4th Gear April 16, 2006 Share April 16, 2006 during this time when your raisin stabiliser was disconnected, did you notice the gear change less smooth or engine less eager to rev? if u didn't, it's high time you remove this raisin stabiliser to prevent further mishaps (or potential short circuit in future) raisin is best mixed with cereals not as volt stabiliser Link to post Share on other sites More sharing options...
Yc86 Clutched April 16, 2006 Share April 16, 2006 (edited) yup the sparks are normal... careful when u touch the live of the battery and accidentally contact the ground/body of the car with the other... will get a numbing sensation Edited April 16, 2006 by Yc86 Link to post Share on other sites More sharing options...
Yc86 Clutched April 16, 2006 Share April 16, 2006 during this time when your raisin stabiliser was disconnected, did you notice the gear change less smooth or engine less eager to rev? if u didn't, it's high time you remove this raisin stabiliser to prevent further mishaps (or potential short circuit in future) raisin is best mixed with cereals not as volt stabiliser lol!! raisins... yummm Link to post Share on other sites More sharing options...
Will_I_Am 2nd Gear April 16, 2006 Share April 16, 2006 That's a close shave! By the way, are voltage stab really that effective? Had one z-stab installed for trial but so far don't find any decrease in FC. Will monitor for another week before I decide whether to return it for a refund. Link to post Share on other sites More sharing options...
Kb27 Supersonic April 16, 2006 Share April 16, 2006 (edited) Sparks are normal. I get it everytime I disconnect/reconnect the battery to do some DIY. You still get sparks even with the engine off. If it don't spark, it means the battery is dying or dead. Edited April 16, 2006 by Kb27 Link to post Share on other sites More sharing options...
Sofarsogood 1st Gear April 17, 2006 Author Share April 17, 2006 Dont get you leh? After connecting back, it seemed smoother. So what's the logic? Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie April 17, 2006 Share April 17, 2006 Diff brand of vs give u diff feel. And so do diff value of cap and some could mix n some could not Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie April 17, 2006 Share April 17, 2006 spark at the positive seems common. but his is at the negative leh... shouldn't have spark rite? i tried my, no spark leh, but positive got spark. Link to post Share on other sites More sharing options...
Kb27 Supersonic April 17, 2006 Share April 17, 2006 It depends on what order you disconnect the battery. The correct way is to remove the negative terminal from the battery first, then followed by positive. Reverse order when connecting back. Since the negative is the last to connect, the spark is there at the negative. Spark is just a surge in electricity when the load is connected, nothing to it. Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie April 17, 2006 Share April 17, 2006 (edited) mosty will got spark if there r power search Means in a sec of power searching (+) or (-) which to which first , Also got spark search. Unless u fix the wrong way then . Pivot fuse will blowup .( protect the cap ) If not u can heard PENG sound then , The cap ass blow a hole Liquid will flow out too lor. ( Smelly man ) Edited April 17, 2006 by Benboy78 Link to post Share on other sites More sharing options...
Trd123 Neutral Newbie April 19, 2006 Share April 19, 2006 Was doing some Diy in my engine bay and discovered the (-ve) cable from my Raizin disconnected from the battery!! Quickly fixed it back. Got shocked a bit by the sparks that flew when I touch the cable to the (-ve) terminal of battery. Anyway, I think it must have been the time when the AA engineer changed my battery, and left the Raizin disconnected. DIDN'T IT FUSE OUT THE RAIZIN? Link to post Share on other sites More sharing options...
Gary84 1st Gear April 19, 2006 Share April 19, 2006 perhaps u want to go bk AA and have your Raizin stabilizer fix back... Link to post Share on other sites More sharing options...
Benboy78 Neutral Newbie April 19, 2006 Share April 19, 2006 So easy to DIY If u need my help. Do pm me . I help u to install back lar. Link to post Share on other sites More sharing options...
Gary84 1st Gear April 19, 2006 Share April 19, 2006 maybe u can help out Sofarsogood... ↡ Advertisement Link to post Share on other sites More sharing options...
Need advice on grounding for Pivot Mega Raizin kit
Pivot 3 Drive Throttle Controller
Review of the Hot Inazma MR and DIY Pivot Spark Earth VS
My DIY Pivot Spark Earth
Anyone installed Pivot AT drive?
Pivot AT drive
Pivot AT drive
Pivot AT drive..good?
D1 Spec & Pivot (blue)
