Wham Neutral Newbie June 7, 2006 Share June 7, 2006 I am having the stock Honda 6 discs front loading HU from KM & I find that be it, I am playing CDs', MP3 or radio, the rear sound is always louder than the front... Bro, pls advise me if by changing the front speakers & installing tweeters, can these components help??? Thanks a millions _________________ Don't Worry Be HAPPY 本田 es5 ↡ Advertisement Link to post Share on other sites More sharing options...
Ae86 Neutral Newbie June 7, 2006 Share June 7, 2006 If you wish to spend money then go get a pair of component speakers preferrably 6.5" the other alternative is to use your hu's fader to fade the sound of the rear speakers so that the front are louder than the rear speakers. Link to post Share on other sites More sharing options...
Wham Neutral Newbie June 8, 2006 Author Share June 8, 2006 but I have already centre the fader & still find that it is not balance or should i say front is soft but rear is loud... Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 8, 2006 Share June 8, 2006 did you install any amp? Link to post Share on other sites More sharing options...
Wham Neutral Newbie June 8, 2006 Author Share June 8, 2006 bro i have no amp leh. stock setup... Link to post Share on other sites More sharing options...
Bluecity Neutral Newbie June 8, 2006 Share June 8, 2006 (edited) Bro, i have been driving 3 honda cars. 1 Civic GL & 2 City. I observe these cars front door speaker is position quite low. You try. if you sit inside the car, try to move your right leg away... or open the door and stand outside the car. You will hear the sound from the front speaker quite clear, I mean clear enough. By fading the sound to the front, you would realised that you are fading quite a lot instead of just 1 or 2 or 3 levels (Driver sitting in the car). I would said it's the position of the door speaker instead of any replacement of good speaker would help. But of course, bu replacing a good component speaker would eventually serve good lor. As the sound quality is sharper and clearer mah. For my case. I didn't change any speakers. I just add 1 set of dome tweeter which wiring tap from the front speaker to create those ching ching sound and a little bit of clarity. I mean, this is 1 very budget way of doing it lor. I have try sitting in the vios and altis. The sound for the front speaker is more clearly than my Hondas. As their speaker position is much higher. Edited June 8, 2006 by Bluecity Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear June 8, 2006 Share June 8, 2006 hmmmm.......I wonder what could be the cause.... Link to post Share on other sites More sharing options...
Ae86 Neutral Newbie June 9, 2006 Share June 9, 2006 Try to fade the sound to the front and not center the fader position, adjust the fader to the front until you bearly notice there is sound coming from the rear speakers. Hope this help. Link to post Share on other sites More sharing options...
Kelvinw Neutral Newbie June 12, 2006 Share June 12, 2006 what do u mean by "fade the sound" Link to post Share on other sites More sharing options...
Kwongwing Neutral Newbie June 12, 2006 Share June 12, 2006 The control knob or function that adjusts the sound between the front and rear speakers is called the "Fader Control" - i.e. one either fades to the front or the rear ↡ Advertisement Link to post Share on other sites More sharing options...
Looking for Job in automotive sector, need advise
Please advise bodywork repair, spray painting workshop
Need advise and help for Axio 2008
Home repair advice needed
Children delivery package .. pls advise
Need advise: got hit by malaysian van from behind
Advise needed - damage to car in condo
