Vincsk2003 Neutral Newbie July 7, 2006 Share July 7, 2006 I DIY. I replace my current AMP with a 1000w AMP. Connect the ground and positive wire on the new AMP. Why is there no power? I thought all AMP using the same voltage? ↡ Advertisement Link to post Share on other sites More sharing options...
Kermit 1st Gear July 8, 2006 Share July 8, 2006 What about the remote wire? Link to post Share on other sites More sharing options...
Notsoblurr Neutral Newbie July 8, 2006 Share July 8, 2006 You need to connect the remote wire (blue) from the head unit (HU) to the amplifier. Link to post Share on other sites More sharing options...
Vincsk2003 Neutral Newbie July 8, 2006 Author Share July 8, 2006 Opps. I think I never. I just connect the positive and ground to my AMP. See no power, I very sad. Anyway. Is it true that all AMP using the same voltage? Link to post Share on other sites More sharing options...
Ae86 Neutral Newbie July 8, 2006 Share July 8, 2006 yes they use 12 v dc power supply. Link to post Share on other sites More sharing options...
Vincsk2003 Neutral Newbie July 8, 2006 Author Share July 8, 2006 Then I think it is very easy to DIY. Just connect the speaker Front L(+) L(-), R(+) R(-), and rear L(+) L(-), R(+) R(-). Then the audio input front on front, rear on rear with the power positive(+) and ground(-) and no forgetting the remote in order to link. Link to post Share on other sites More sharing options...
Notsoblurr Neutral Newbie July 9, 2006 Share July 9, 2006 Then I think it is very easy to DIY. Just connect the speaker Front L(+) L(-), R(+) R(-), and rear L(+) L(-), R(+) R(-). Then the audio input front on front, rear on rear with the power positive(+) and ground(-) and no forgetting the remote in order to link. If you have a amplifier before, then it is easy to change. If you are installing a complete new amplifier, you need to lay a power cable with fuse from your car battery to the amplifier. It is a lot of work going through the the car dash board from the engine compartment. Tunning the amplifier need expertise too. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Changing halogen to LED
How close to wear indicators before changing tires?
Changing coins to notes
Scirocco - Changing to LED lights
Cost of changing headlamp bulb, foglight bulb
Changing language display to English for PI Toyota Harrier
