How to Switch Off Exhaust Fault Signal Light?
Putter
Ya lor...safety 1st. According to Philip, if not solved and the issue get worst. The firing will be unbalance and causing the car to jerk. Extreme case due to accumulation of petrol may even cause fire. I can't imagine this happen along NS Hwy.
This is interesting...
2 days ago had my 15K oil change, followed by resetting of ECU (3rd time). Now no more sensor light warning. Pick-up/ acceleration back 2 normal, damn shiok. Turbo kick in damn smooth.
Still remains a mystery why my sensor light warning appeared previously.
I believe this problem is linked to the supplier of the coil packs. Putter's Superb (MY2004) is the first case I have encountered in Singapore. Till date, I have no news of Superbs MY2005 and later which have encountered similar problems.
Keep our fingers crossed that the first batch of Superbs sold in Singapore are equipped with the 'H' type ignition coil packs.
For your reading pleasure.
http://www.mylemon.com/VW_18T.html
http://forums.audiworld.com/a4gen2/msgs/157701.phtml
Additional info on where the coil packs reside.
http://www.s-cars.org/postnuke/downloads/p...nstructions.pdf
Went to Servo just now over lunch. Philip diagnosed it and found 4 miss-firing fault on coil#1. So it seems to be a consistent real issue on the firing. Spark plug just changed 2 months back. So he suspected due to the spark plug coil issue and I asked him replaced all the 4 coils. I tested with "kick-in" and no more issue. [thumbsup]
According to Philip, this type of issue frequently happen on the 1.8T engine. Earlier coils were not so robust to high temperature and suffered early failure.
I think I better get my checked out. my car is from that batch. My car is a little jerky when on manual and it down gears due to lower speed.
Will ask servo to check it when I get the chance.
Could you PM me the cost of replacement.
Lamy
