Turbonetics 2nd Gear November 25, 2006 Share November 25, 2006 anybody knows what are difference between the DC5R and CL7R other than the Brembo on the DC5R? does the Euro R comes with LSD also? ↡ Advertisement Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear November 25, 2006 Share November 25, 2006 I suggest you goto www.integra.sg to find out more. There're a few bro's who switched from DC5R to Euro R when family outgrew the coupe. DC5R and EuroR gear ratios are same up to Gear 3, after which the Euro R has taller gear ratios as it's not a pure track machine. EuroR comes with its own LSD. This is a good guide forgear ratios comparisons: http://www.fatboyraceworks.com/gears/ Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear November 25, 2006 Author Share November 25, 2006 (edited) thanx man.iam not a member of Teg Sg club but will check it out there. so i guess for the gearing,can just swap the type R gearbox into the euro R will do? Edited November 25, 2006 by Turbonetics Link to post Share on other sites More sharing options...
Ml2spin 2nd Gear November 25, 2006 Share November 25, 2006 Err... what's the point of swapping gearboxes? If you need shorter ratios, drop in a shorter final drive first. Anyway the key difference is weight - DC5R/Integra is 200kg lighter than CL7R/Euro R so if you really want to build a non-turbo track monster, get a DC5R. The CL7R can be modified to run quite well at Sepang but 200kg weight disadvantage really hurts since squeezing more power/torque out the already high-revving K20 engine isn't as easy or cheap as turbocharged engines. Link to post Share on other sites More sharing options...
Ck2998 Neutral Newbie November 25, 2006 Share November 25, 2006 Another difference is in the suspension. DC5R has front MacPherson struts and back double wishbones while CL7R has all double wishbones. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear November 26, 2006 Author Share November 26, 2006 thanks all for the reply. anymore to add on? Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear November 26, 2006 Author Share November 26, 2006 are you sure their weight differ by 200kg?seems like too much for me. Link to post Share on other sites More sharing options...
Nazaki Clutched November 26, 2006 Share November 26, 2006 Slightly OOT but. Both are coming to the end of production right? Any news of their replacement? Link to post Share on other sites More sharing options...
Vblaster_w211 2nd Gear November 26, 2006 Share November 26, 2006 Euro R is still in production. Integra has stopped production. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear November 27, 2006 Author Share November 27, 2006 the new Civic Type R. Link to post Share on other sites More sharing options...
Dodobird Neutral Newbie November 27, 2006 Share November 27, 2006 euro r around 200+ kg more. so heavy that, 0-100 is 1sec+ apart. Link to post Share on other sites More sharing options...
Ml2spin 2nd Gear November 27, 2006 Share November 27, 2006 YUp - very sure. From Honda Japan website, Integra Type R weighs 1190kg while Euro R weighs 1390kg. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear November 27, 2006 Author Share November 27, 2006 ok thanks. you know their exact century sprint timing? ↡ Advertisement Link to post Share on other sites More sharing options...
Disputes between neighbours - A True story
Income tax Evasion
Income tax Evasion
Euro 2024
Euro 2024
SGD to EURO
SGD to EURO
What type of car air freshener ?
Laundry Drying system - Pull-down/Push-up type
Any Honda Accord Euro R (CL7R) kakis here?
