Poserwoo Neutral Newbie December 24, 2006 Share December 24, 2006 Just change my suspension to KYB shock cum B+G lowering springs. Somtimes there's clock clock sound from the rear....wat that sound from??? ↡ Advertisement Link to post Share on other sites More sharing options...
Bulls_is_back 1st Gear December 24, 2006 Share December 24, 2006 maybe the springs didn't "sit" properly Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 24, 2006 Share December 24, 2006 Maybe the springs wasn't installed properly. Go check again. If still got noise, change back to stock springs. If no noise, then it's the B+G springs problem. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie December 24, 2006 Share December 24, 2006 Yes, hoist up and check all the bolts/nuts again. Have you chagne the rubber mountings as well? The mountings could have shrunk in size and will not cushion nicely anymore. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear December 25, 2006 Share December 25, 2006 Better Go Check First..........Cornering......Problem...... Probably Nuts Not tighten........ Link to post Share on other sites More sharing options...
Poserwoo Neutral Newbie December 25, 2006 Author Share December 25, 2006 Used back the stock rubber mounting, onli 1 yr plus pld. Link to post Share on other sites More sharing options...
Ccssgm 1st Gear December 25, 2006 Share December 25, 2006 Maybe the Stock Rubber Mounting Not Fix It........... Link to post Share on other sites More sharing options...
Poserwoo Neutral Newbie December 26, 2006 Author Share December 26, 2006 where to get rubber mounting? Link to post Share on other sites More sharing options...
Ccssgm 1st Gear December 26, 2006 Share December 26, 2006 [rolleyes]Mechanic Should Know......Better ..... Link to post Share on other sites More sharing options...
Poserwoo Neutral Newbie December 26, 2006 Author Share December 26, 2006 Oredi got the new sets of springs to sit in...tik needed time for it to sit in. kekekeee Link to post Share on other sites More sharing options...
Ccssgm 1st Gear December 26, 2006 Share December 26, 2006 Link to post Share on other sites More sharing options...
Poserwoo Neutral Newbie December 30, 2006 Author Share December 30, 2006 Today sudden went over a hump, too late to brake so just went over, tik impact something that now my front suspension whenever went over uneven ground or go over hump will have loose part sound....sigh...... Link to post Share on other sites More sharing options...
Swingit Neutral Newbie December 30, 2006 Share December 30, 2006 Sometimes you just have to grease the springs. Link to post Share on other sites More sharing options...
Poserwoo Neutral Newbie December 31, 2006 Author Share December 31, 2006 Can i spray lubricant? Link to post Share on other sites More sharing options...
Swingit Neutral Newbie January 1, 2007 Share January 1, 2007 i think its better to get a pro to do it.A similae thing happened to me and i took it to my mechanic. they told me they took out the springs and greased it. that seemed to have solved the problem.But either ways its better to get yourcar checked out,it could be a number of other reasons you are getting the sounds.good luck. Link to post Share on other sites More sharing options...
Teddi Neutral Newbie January 2, 2007 Share January 2, 2007 What is your car model? Link to post Share on other sites More sharing options...
Poserwoo Neutral Newbie January 2, 2007 Author Share January 2, 2007 yup going to workshop on wed, PH period most of them close...mine drive is Honda Jazz. ↡ Advertisement Link to post Share on other sites More sharing options...
ACG Performance - Official Distributor For Brembo, AirBFT Air Suspensions & GFG Forged Wheels!
Front lower arm and suspension questions
Is your car worth what it cost? [Shocking]
Noise from front engine area (suspension,maybe) when hit bump with left turn
TTC urethane cushion buffer
