Gravestone January 5, 2007 Share January 5, 2007 What are the factors that contribute to higher FC of two different make of cars if both are of similar weight, capacity, specifications and mileage after considering that the same person driving the cars in the same manner? ↡ Advertisement Link to post Share on other sites More sharing options...
Caravan 5th Gear January 5, 2007 Share January 5, 2007 Engine technology, maintenance, running-in process, worn gaskets etc Transmission efficiency for e.g. CVT vs conventional auto Gear ratio, num of gears Aerodynamic (drag coefficient) Air con efficiency, differences in ICE etc Tyre differences, e.g. low rolling resistance tyres my 2cents.. Link to post Share on other sites More sharing options...
Ae101 Neutral Newbie January 6, 2007 Share January 6, 2007 cars of different make sure have different FC. it is almot impossible to make them the same... Link to post Share on other sites More sharing options...
Adawang 1st Gear January 6, 2007 Share January 6, 2007 cars of the same make and model , fc is also different Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear January 6, 2007 Share January 6, 2007 Wah... what caravan listed barely scratches all the variables.... Theres way too much to list. Link to post Share on other sites More sharing options...
Gravestone January 6, 2007 Author Share January 6, 2007 Thats true lar but for eg if a car is heavier than the other, we can all then understand the reason behind the higher FC of that car of that class rite? But wat if a better tech car's engine is fitted into a model that is not "well engineered", will it churn out better FC assuming again that both cars are of equal or almost equal specifications? Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear January 6, 2007 Share January 6, 2007 well you have to realise that even a different viscosity engine oil, dirt on the exterior that increases drag, etc makes a difference. Generally if everything else being exactly equal, a similar engine that has variations designed for fuel economy will have better FC ( a non-FC example would be the SR20DE silvia vs the SR20DET silvia. identical cars, different engines. Do you think the TC version would perform better or the non-TC version). If both engines are exactly equal but the other FC aspects are different, then the results should be roughly the same regardless of which engine is in which car. A non-FC related example would be the the VQ35DE cefiro/maxima vs the VQ35DE 350z. Same engine, similar weights, but one car was designed for performance and the other comfort. Which do you think handles better and which do you think is more comfy. Even if i swapped the engines around the results would be the same. Now if you're talking abt different cars with different engines with weight being the only thing equal, then its impossible to compare. To simplyfy this, tell me, do you think an apple tastes better or an orange tastes better? It depends on the variable... which is the person who is eating it. Link to post Share on other sites More sharing options...
Gravestone January 6, 2007 Author Share January 6, 2007 Hmmmm.....logical reply but then there wld be no end if i were to keep pondering on the issue...thanks a million bro... Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear January 6, 2007 Share January 6, 2007 Its a good question but a bit of a moot point in sg coz we cant change engines. Just focus on your foot (cannot be heavy like mine and maintain the engine and bodywork and you should be fine. Link to post Share on other sites More sharing options...
Ae101 Neutral Newbie January 7, 2007 Share January 7, 2007 depends on the oil n wheels u use.tyre pressure is also vital. driving habits too. if all are the same, then it shoud be manufacturiing problem. care to share more ?? ↡ Advertisement Link to post Share on other sites More sharing options...
Where to mod fuel needle?
Fuel Plus Meet Up
Fuel Plus Meet Up
