Newbie!!!
Fisheye
Ignore her......she not in good mood coz i din meet her for BF this morning.....laugh.giflaugh.giflaugh.giflaugh.gif
like PHD say....he just make you prata....he around i no need to show hand
guys...sometimes it's very ironic....here we are talking in a thread where somebody started, but that somebody is not around......like twilight zone sometimes.........whazzup brudder......
you are right, we should not be drifting......but.....sometimes difficult to control. but please make sure that all of us are quick to reply when questions have been posed. not fair to hijack his thread and he does not get his infothumbsup.gifthumbsup.gif
Ok Ok, back to tire pressure, read this:
I highlighted in red the important point for 195/55 R15
The Benefits of Correct Air Pressure
Keeping the correct air pressure in your tires is as important as giving
your engine a tune up. The economic benefits are perhaps even greater!
With the right amount of air pressure, your tires wear longer, save fuel,
enhance handling and prevent accidents. If you consider the liabilities of
not maintaining the correct air pressure -- poor gas mileage, loss of tire
life, bad handling (perhaps even loss of control), and potential vehicle
overloading -- then the need to routinely add air to your tires will
become clearer.
Check Air Pressure Routinely
Perhaps because our tires do so much without seeming to need any
attention, we tend to overlook this important task. But tires do lose
pressure, slowly but surely everyday, through the process of permeation.
Generally, a tire will lose one or two pounds of air per month in cool
weather and even more in warmer weather. Also, tires are subjected to
flexing and impacts that can diminish air pressure. So, think in terms of
refilling your tire just like you do your gas tank; actually that's a good
reminder, refill your tires every other time you fill up at the gas
station. That's the recommended interval. Another time to check air
pressure is when the tires are rotated. Many vehicles have different tire
pressures on the front and rear axle, so remember to have this
adjustment made. Also remember to have the pressure in your spare
checked. The space-saver type spare requires a much higher air
pressure level than other tires and is virtually useless (due to
overloading) at lower air pressure levels.
Where To Find Air Pressure Information
The correct air pressure may be found in the vehicle owner's manual or
on the tire placard (attached to the vehicle door edge, doorpost, glove
box door or fuel door). If you have trouble, see a local tire dealer
for assistance; check our directory for the nearest Discount Tire or
America's Tire store. The placard tells you the maximum vehicle load,
the cold tire pressures and the tire size recommended by the
vehicle manufacturer.
Another valuable resource is the Tire Load/Inflation Tables. Your nearby
tire dealer should have a copy. Not only will this document tell you the
correct tire pressure for stock sizes, but it will provide the information on
optional plus sizes as well. A good example would be the findings on a
Honda Civic with the stock size 185/65R-14; recommended air pressure
is 28 psi. Plus one size is 195/55R-15 with a recommended air
pressure of 32 psi. Plus two size is 205/45R-16 with a recommended air
pressure of 36 psi. Note how the air pressure increases with plus sizing
to meet the load carrying capacity for the car.
Other Factors Change Air Pressure
Besides the routine air check, other circumstances necessitate a visit
to the air pump. Seasonal changes or altitude changes create a
rise or drop in air pressure (for every 10 degrees change in
temperature, tire air pressures changes 1 psi). But perhaps the
most overlooked factor is vehicle loading for trucks and RVs.
Since these vehicles can be configured and loaded in many ways,
the proper inflation pressure should be determined by actual tire
loads. This is best determined by weighing the vehicle; vehicle
loading can change from trip to trip.
Remember that tire failure can occur
due to under inflation and overloading!
One of the most dangerous conditions that can exist is the slow leak.
Sometimes a small nail, screw or other object will puncture a tire
and then act as an inefficient plug. Air pressure drops slowly
over a matter of hours or days, undetected by the driver. Your best
defense in this circumstance is to be alert to the symptoms of this
condition. Be aware of any pulling or vibration that seems unnatural.
And listen for any tick-ticking sound -- especially audible at slow,
parking lot speeds. If you detect this, get off the road and inspect
the tires on the side of the pull, vibration or sound. A bulging
sidewall and/or excessively hot tire indicates a slow leak. Put
on your spare tire and have your tire dealer repair the punctured
unit. Ask the repair technician if any sidewall damage has occurred
(a powdery residue inside the tire indicates this condition). If so,
have the tire replaced.
How To Check Air Pressure
Properly checking tire pressure requires an accurate air gauge. Many
people believe that they can check air pressure just by looking
at the tire and judging the sidewall appearance. Also, many people
use the air meters at service stations, which can be grossly
inaccurate due to exposure or abuse. Invest in a quality air gauge.
For trucks and RVs, use a dual-head inflation gauge that is
calibrated up to 120 psi at 2 psi increments.
When checking your vehicle's tire pressure, make sure the tires are
"cold". Cold air pressure means that the vehicle has not yet
been driven one mile (remember that driving on a tire increases its
temperature and air pressure). If you must drive more than one mile
for air check and record the air pressure in all your tires before
you leave. Once at the tire dealer, measure each tire's inflation
again and then note the difference. Inflate the tires with low
pressure to a level that is equal to the recommended cold pressure
plus the difference at the higher temperature.
In this example, add 3 psi in the right
rear tire to match the other rear tire's
warm reading. When the tire returns to
cold pressure, it should end up at the
recommended pressure.
Finally, after completing the pressure check, make sure the valves and
extensions are equipped with valve caps to keep out dirt and moisture.
Remember to replace the valve assembly when you replace the tire;
it's your best assurance against a sudden or consistent loss of
air pressure.
Environmental Impact
How can routine air pressure maintenance impact our environment? Consider
that fewer tires per year would end up in the landfills and scrap
heaps that trouble our ecology. How many tires are we talking about? We
estimate that most drivers lose from 10% to as much as 50% of tire tread
life due to underinflation. That's a significant statistic. Now consider
the extra fuel we burn to push cars along on soft, underinflated tires.
Tires do require extra energy to roll if they are under inflated. While
the statistics vary widely and inconclusively, the implications are
staggering. So maintaining tire pressure is a small line item in our busy
daily routines, but it adds up to big environmental consequences. We
must all care and take action to do the right thing.
Dun be so happy, see whether your gang members got staying power not, later like the humsaabs, 'neng' liao, no power leh! [;)]
Sigh... He don't know it's different model meh...
He is still the only one with VIP. [sly][laugh][laugh][laugh]
Edited by Gadgeter
welcome to MCF.....its better late than never correct boh. enjoy yourself and hope to see you at our meetups
I drive the VIP B15. using a 195/45/15.....still getting 12.5km/l not that bad. i using 32psi and am happy with it.
JAZZIEGIRL/SAABER/GAD - i got new member to my VIPER club....you all dun pray pray i tell you all. laugh.giflaugh.giflaugh.giflaugh.gif
Aiyo... put your rims, steering wheel over lah... Me no scare one.. [laugh][laugh][laugh]
Pai Kia.....dun drift.....me and PHD take so long to come back to course and you just come here and cut lane again........got see the prata above or not.....want to be them or not!!! PHD!!!!laugh.giflaugh.giflaugh.giflaugh.giflaugh.gif
