Toalson 1st Gear January 29, 2007 Share January 29, 2007 Can anyone explain this to me. Sorie, I'm a newbie. Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Protege 1st Gear January 29, 2007 Share January 29, 2007 Frequency should cut off where your front components could not hit. Typically good pair of components can hit about 50Hz or so. So you can set your frequency cut off about 50-60Hz. As for the gain, can your HU control sub volume? If can then you can put your sub gain to around 3/4 and then control from the HU. If not then you have to adjust until you find the bass sufficient. There will be other gurus out here should be helping you soon! Link to post Share on other sites More sharing options...
Toalson 1st Gear January 29, 2007 Author Share January 29, 2007 So u meant that gain = volume? And yes, my Hu can control the volume. Link to post Share on other sites More sharing options...
Protege 1st Gear January 29, 2007 Share January 29, 2007 When I mean volume, its volume of the sub, not the main speakers. Link to post Share on other sites More sharing options...
Toalson 1st Gear January 31, 2007 Author Share January 31, 2007 Yes I understand you. Adjusting the volume control for the sub from the HU. But my 2nd question is the gain control on the sub = volume control of the sub on the HU? Tks! Link to post Share on other sites More sharing options...
Bobcatsysop Neutral Newbie January 31, 2007 Share January 31, 2007 Hi Bro, <he gain control on the sub = volume control of the sub on the HU? >> Nope.. you need to do gain matching of your HU sub level to match your volume control of your sub. You need to play a 'strong bass' track to repeat that same track while you do gain matching for your sub. For example if this is your HU volume control. Set your HU volume control to 2/3 of the max. Max: 62 if this is your max. Loud:41 - 2/3 of max Norm:21 - 1/3 of max. First, lower your volume control on your sub. Then go to your HU.. At 2/3 of the HU volume, at 41, you play just your 'strong bass' track. Then you slowly raise the volume of your sub until you hear flutter/distortion from your sub. Lower that down a little until you hear no distortion. That is your max volume of your sub to match your HU at 2/3 of max. Hope this helps. Link to post Share on other sites More sharing options...
Protege 1st Gear January 31, 2007 Share January 31, 2007 For me, my volume control for sub is max at 15. So I put the sub volume between 10-12. And then increase the sub gain till I get the bass that I want. In the above instance, if some tracks are less in bass, you can increase the sub volume. If too much bass, you can reduce the sub volume. Hope my above method helps! Link to post Share on other sites More sharing options...
Toalson 1st Gear February 1, 2007 Author Share February 1, 2007 Oic... will try. tks! Link to post Share on other sites More sharing options...
Toalson 1st Gear February 1, 2007 Author Share February 1, 2007 Tks for the explanation. ↡ Advertisement Link to post Share on other sites More sharing options...
Is Turbonator = Air Charger = E68??? (30% HP Gain!!!)
Recommend under seat active sub
Questions on my active sub LPF crossover
Active vs Passive Setup
Active Brake Assist function limited
Help in changing time settings on MCF
What to Do in an Active Shooter Situation
Keeping Your Sex Life Safe, Fun And Active
