Bleuzone 1st Gear April 22, 2003 Share April 22, 2003 Hiya, just wondering, my amp's a bit weird. I just sent it for repair cus something worng. It's working fine at the shop, but when I install it into my car, the amp like got no power! The sound that comes out softer than if I use the HU itself. But when I bring it back to the shop to test, seems ok. Connections all no prob. I got 2 amps, 1 for sub, one for speakers, and the sub's working fine. Its a 4 ch amp. Just connect the input and outputs, should be ok rite?? Does anyone have any idea? Feel like bringing it back to the shop and trade in for another one... ↡ Advertisement Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 did you re-adjust the level on the amp? the screws to tune the treble and stuff? Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 Yeah! Put the gain to max... Actually, I put everything to max to test it out, still like dat... The sound very very soft Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 grounding all done properly? Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 I should think so. Tapped the power and ground from the 1st amp. Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 why you tap from the first amp? the power should come in from battery all the way then split to two with the fuse box.....not tap from the first amp Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 (edited) Erm... Dunno how to explain... The power came from the batt, then at the power input for the 1st amp, I join another cable to the second one.I guess it works the same as direct from the batt... Edited April 22, 2003 by Bleuzone Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 like that hor....if anything blow, both amp will blow.....bad setup Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 (edited) Hmm... But there are fuses on both the amps leh... Didn't bypass the fuses. Connected to the proper power input... Is it still bad? Edited April 22, 2003 by Bleuzone Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 i burnt my amp the other day....i have fuses everywhere..........dun depend only on the fuse in amp. its not good enuff Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 come down friday.....let me have a look. Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 Okie... But I think I'll go back to the shop tomorrow first... See if can change the amp. I think the amp maybe something wrong, cus I tried it on my subwoofer but couldn't work as well... The weird thing is that it works at the shop! But he uses his own connections and speakers... Maybe if can fix Fri I show you my DIY efforts... HAhaha! a bit messy I should say, but if it works, then quite rewarding... Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 you did everything yourself? Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 Yeah, from the buying of the cables to the running of it... All the way from front to the back. Plus speaker wires too... Wah, quite shaq!!!! Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie April 22, 2003 Share April 22, 2003 becareful about this bro.......any short circuit and the car can be gone hor Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 22, 2003 Author Share April 22, 2003 Okie... Very careful liao... I know the car might catch fire if I wire wrongly... THought of it liao... Thanks for the advice!!! Link to post Share on other sites More sharing options...
Astralee 2nd Gear April 22, 2003 Share April 22, 2003 maybe u connect the circuit wrongly liao? possible? coz if u connect in series circuit, all tha current from yur batt will go to the first amp, thus not enough current going to yur 2nd amp liao. tat may be y it works in the shop but not yur car. Link to post Share on other sites More sharing options...
Bleuzone 1st Gear April 24, 2003 Author Share April 24, 2003 Okie, went to SLT to change amp. It's working fine now!!! The amp was weird. Worked at the shop but not in my car........ ↡ Advertisement Link to post Share on other sites More sharing options...
Weird Laws
Weird Laws
Russians Covering a Car with 300 LED Lightbulbs
Weird FETISH and what is yours?
Weird OMV valuation
Weird OMV valuation
Is it weird to add a stranger in What'sApp groupchat?
Nissan Latio Weird Problem
Weird trumpet noises in the sky?
Weird World Indeed - Circumcision Suction Ritual
