Lastdance Neutral Newbie May 1, 2007 Share May 1, 2007 Hi Guys, May I know what needs to be done at 80000km servicing? Roughly how much is the damage for a 1.5M Fit and where do you all recommend for this job. Thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Limitedspeed Neutral Newbie May 1, 2007 Share May 1, 2007 At 80k you should seriously be looking at your brake pads be it disc or drum ... well all other things aside Link to post Share on other sites More sharing options...
Dankoo 4th Gear May 1, 2007 Share May 1, 2007 just did my 80K...refer to my thread..scroll to last page...if yours have timing belt...that is the bomb... http://www.mycarforum.com/forum/Aftermarke...amage_P1547162/ Link to post Share on other sites More sharing options...
Lastdance Neutral Newbie May 1, 2007 Author Share May 1, 2007 Thanks for the heads up! I'm actually taking over a 2nd hand car, new to cars so dunno where to go. Any recommendations for Honda Fit 1.5M? Link to post Share on other sites More sharing options...
Lastdance Neutral Newbie May 3, 2007 Author Share May 3, 2007 Help? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 3, 2007 Share May 3, 2007 (edited) Bro, generally 80K servicing should include the following:- 1) Change of all fluids i.e Brake, Power Steering, Gear Box, Coolant. 2) Timing Belt, Power Steering, Fan Belt, Water Pump Assemby, Water Pump Bearing. 3) Front & rear brake pads/drum. 4) General engine oil change & checks For brakes, it may or may not need to change depending on conditions Edited May 3, 2007 by Mzrmazda3 Link to post Share on other sites More sharing options...
Route88 2nd Gear May 3, 2007 Share May 3, 2007 ...basically a lot of things need to do The most impt part is timing belt Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 3, 2007 Share May 3, 2007 Yeah Bro Once that timing belt snaps, god bless the pocket of that ride's owner Link to post Share on other sites More sharing options...
Lastdance Neutral Newbie May 3, 2007 Author Share May 3, 2007 Thanks guys, how much would it cost and which workshop you guys recommend for Honda Fit 1.5M? Link to post Share on other sites More sharing options...
Route88 2nd Gear May 3, 2007 Share May 3, 2007 I think most Honda nation rec. Riverview at sin ming...you can check on them...not sure the exact addy. Link to post Share on other sites More sharing options...
Seanboi 1st Gear May 4, 2007 Share May 4, 2007 For number 2, Is it standard for all cars? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 4, 2007 Share May 4, 2007 (edited) Bro, not the same Some makes change at 60K servicing, some at 80K servicing while some even at 100K servicing Some jus change the beltings but did not change the water pump assembly and it's bearing Edited May 4, 2007 by Mzrmazda3 ↡ Advertisement Link to post Share on other sites More sharing options...
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Workshops with engine oil flushing machine
Volvo Servicing
Volvo Servicing
