Battery can last how long without charging?
Vios73
I will be away for 2 weeks and wish to gather from bros here whether without charging (starting of engine) the battery, can my car battery last till then? I was planning not to arm the car with alarm and just key lock to preserve the battery power. Advise pls. Thanks.
should be ok, at least it was ok for a bike after resting for 2 wks.
if not if you can always stand by a friend or colleague to help jump start your car, in necessary.
Shouldn't be much of a problem... the battery should last quite long actually... unneccessary to key lock cos the alarm should drain much of the battery...
as a precaution, just remember to check the physical condition before starting up due to corrosion or leaks... top up battery water if it runs low too..
How old is your battery? mine almost 2 years old batt died on me suddenly w/o warning. the day before i'm still able to crank the engine easily
