Assaxefour 1st Gear March 25, 2008 Share March 25, 2008 Ya i guess you right. will bring down to eastgear to have them check. ↡ Advertisement Link to post Share on other sites More sharing options...
Beei 1st Gear March 25, 2008 Share March 25, 2008 I was attracted by the SLA/Mapking maps also.. but not very useful in Malaysia.. Lot of places not inside.. But I think the advantage of Holux is that it is more user friendly.. Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear March 25, 2008 Share March 25, 2008 same, the moment i know the maps are updated and dun need to force ppl to make contributions.. mai tu liao... Link to post Share on other sites More sharing options...
Beei 1st Gear March 25, 2008 Share March 25, 2008 and the update frequency also good.. every 2 months or so.. Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear March 25, 2008 Share March 25, 2008 yea Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged March 26, 2008 Share March 26, 2008 I realised my Holux 53C was not holding its charge. The batt meter wont show more than 3 bars even when fully charged and will go flat in 15mins once disconnected from power source. It used to be able to function 2-3hrs on its own power last time. I called Eastgear and they gave me a solution: 1) Disconnect unit from power source 2) Exit from GPS mode to the mode where you can alter settings (where you can see batt meter) 3) Turn off the unit by pressing on the power button for 3 secs 4) Then reconnect the charging cable Tried it and seemed to work. Just in case it happens to your unit too. Link to post Share on other sites More sharing options...
Madsumm 1st Gear March 26, 2008 Share March 26, 2008 (edited) Garmin is not without glitches anywayz...and you have to be rather techno savvy to play around with it. I'm not one for crying out loud and I find the search function (in Garmin) quite unhelpful at times (my very own shallow opinion only...die-hard garmin supporters plse dun whack me) Can I wack u.... pleeeezzzzzzzzzzzzzzzzz? Edited March 26, 2008 by Madsumm Link to post Share on other sites More sharing options...
Beei 1st Gear March 27, 2008 Share March 27, 2008 Warning to all Holux 53CL user. Cannot install map into the GPS you go update the version at eastgear as some of the bros here do.. Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 27, 2008 Share March 27, 2008 i second that! Chickenfarm - It is not that hard if u take effort to read the wikis, right Never read right? Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged March 27, 2008 Share March 27, 2008 Bros...dun whack me I confessed tt I is techno idiot liao mah There's nothing wrong with the set lah, the problem is me Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged March 27, 2008 Share March 27, 2008 My malsing map is outdated (June 2007)...and I dunno how to contirbute, that's why I took the shortcut and "contributed" to Eastgear instead Holux's search is easier cos can search via postal code and they have regular updates via email. I'm switching between the 2 but mostly still using Garmin. Onething I find is that Garmin and Holux will plan different routes to same destination, i.e., Garmin one route but if u use Holux, the route is different. Then in Holux itself, the SLA map is one route and if u select malsing map, the route is different again although same destination Not complaining lah...just my idiotic observation nia nia Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 27, 2008 Share March 27, 2008 So being the users of the two top brands in SG, which route is better for same destination and which is better in terms of functionality wise Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged March 27, 2008 Share March 27, 2008 Wah bro...mai lai sio hai...whatever I say either side will whack me leh Both sets are good I is no good Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged March 27, 2008 Share March 27, 2008 (edited) Okay I give an example... I was on Hampshire rd and my next destination is Autobacs. Garmin says turn right (Kampong Java) then Thomson rd and then turn left onto Whitley rd and then PIE... Holux says turn left from Hampshire rd onto Kampong Java, then turn right onto Bkt Timah then PIE, etc... And bcos I left both GPS sets in my car (white elephant somewhat) and hence it's always cold start, if I need to get out of a place fast fast I'll use Garmin cos the logon is faster (in my humble opinion nia nia) and if I need to travel on roads which I knew got changes bcos of road widening or roadworks, diversions, I use the Holux cos the maps are updated Edited March 27, 2008 by Chickenfarm Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear March 28, 2008 Share March 28, 2008 (edited) Anyone got the jan or feb map update for 53? I didnt see the msg properly went to update the map only to realise cannot use cos I haven update the filmware. Anyone has it can send? Need it urgently thanks Edited March 28, 2008 by Enzomatrix Link to post Share on other sites More sharing options...
Enzomatrix 2nd Gear March 28, 2008 Share March 28, 2008 up Link to post Share on other sites More sharing options...
Chickenfarm Turbocharged March 28, 2008 Share March 28, 2008 My 55 set just bought leh...no updates so far but did receive one email saying if having load map problem go to eastgear ↡ Advertisement Link to post Share on other sites More sharing options...
Lai..lai..lai..Dirty Old Men fall in....
MCF Tennis Kakis fall in!
W212 owners, please check-in
Marbella DashCam Users
