Fkfs9 Neutral Newbie October 10, 2007 Share October 10, 2007 Hi pros, I have a budget of 500 - 600 $ and thinking of adding to my rainbow components speakers. My current HU frm BM comes with ipod connection via some ipod cable so my HU basically can select the songs i want. I checked the user guide and it says output is 40w. I am looking at some alpine's with similar capabilities and I believe there are HU's in the market currently. My concern is, since my ipod's output is also limited, would changing the HU or adding an AMP be a better choice? Currently no SP done, no intention of adding a subwoofer and looking for a warranty set HU or amp. Can anybody give any suggestions? ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear October 11, 2007 Share October 11, 2007 depend on wat model, i suppose is a mid bass speakers? on the front doors? u can consider adding Class D/mono amp if u want to deliver more then 40W to each speaker. but must find out if they r running on 2 Ohms or 4 Ohms. since no subwoofer, probably dun need a crossoveror 4 channel amp. 2 channel will suffice. as the tweeter will hv it's own filtering. Link to post Share on other sites More sharing options...
Fkfs9 Neutral Newbie October 11, 2007 Author Share October 11, 2007 the speakers are CSX 265 from rainbow on the front doors. a Class D mono amp? Erm.. any particular brand? so your suggestion is to get AMP over HU.. thanks alot bro. Link to post Share on other sites More sharing options...
W13ng Neutral Newbie October 11, 2007 Share October 11, 2007 sorry bro.....hijack your thread! Some question! recently driving a airwave w/ stock speaker, HU JVC double din cd player w/ budget of $500... any recommemded comp. speaker + amp....but only listen to radio Link to post Share on other sites More sharing options...
Spinworkx Clutched October 11, 2007 Share October 11, 2007 Your cheapst alternative is to just add an amp and change the speakers. You dun need a new HU if you can live with your stock one :) As for amps, al you need is a 2ch amp to power the front speakers. Depending on your HU, if it doesn't have any outputs, you'll need to get an amp that can accept speaker inputs...like the Alpine...so you dun need processors or hi-lo converters etc....so far i nonly know of Alpine amps that can accept direct speaker inputs as well as RCA inputs Link to post Share on other sites More sharing options...
Apollo 1st Gear October 11, 2007 Share October 11, 2007 CSX 265 same case as mine. so most likely is 2 Ch 4Ohms and ard 300W I would say is spend, bargain with the ICE shop lor. the Amp + wiring + labor (tuning) will not set u back by tat much. a higher end wud b Rockford Fosgate P325.2 which deliver 80W x 4Ohms, and has an external potentiameter so u can adjust the Bias at will. http://www.millionbuy.com/rocp3252.html but bear in mind tat is a mid bass. so if u r discerning type, best u look for a 4Ch amp which you can later add on a 10"/ 12" woofer if the sound image/ quality dun make the cut. Link to post Share on other sites More sharing options...
Apollo 1st Gear October 11, 2007 Share October 11, 2007 just a 2 way component + tweeter on front, powered directly fr HU will do the job. reset speakers by fading off the rear speaker. Link to post Share on other sites More sharing options...
Route88 2nd Gear October 11, 2007 Share October 11, 2007 Get a decent matching power amp for your Rainbow. Link to post Share on other sites More sharing options...
Fkfs9 Neutral Newbie October 11, 2007 Author Share October 11, 2007 frm the link, i assume this amp gonna cost ard 300 SGD. There's this reputable shop that is recommeding a steelmate amp+woofer underneath driver seat also around 300+. So I just go for a dedicated amp instead of a 2-in-1 kind? Link to post Share on other sites More sharing options...
Apollo 1st Gear October 12, 2007 Share October 12, 2007 it's really up to you, but do bare in mind, it's still mid bass. so if u r looking for the omph factor like a KTV/ Discotechque, it wud b hollow. in short not full spectrum of music coming thru. but u r right, u can add on at a later stage if u decides for a woofer. amps under seat is no issue, just make sure the feller knows how to install without drilling holes into the floor pan to secure it in place. next is of cos method to power on and power off the amp. ↡ Advertisement Link to post Share on other sites More sharing options...
