Hktan Neutral Newbie June 3, 2003 Share June 3, 2003 Agree with u! I will carry the spare as well! ↡ Advertisement Link to post Share on other sites More sharing options...
Milgram Neutral Newbie June 3, 2003 Author Share June 3, 2003 Hi Eyke Was just wondering if there is any difference between a 14" rim that weighs about 6.5-6.8kg and a 15" rim that weighs about 6.5-6.8kg in terms of the weight pulling down on the car... Thanks! Link to post Share on other sites More sharing options...
Eyke Supercharged June 3, 2003 Share June 3, 2003 (edited) wrt to grip ("weight pulling down on the car"), if weight is same then should be no difference. Edited June 3, 2003 by Eyke Link to post Share on other sites More sharing options...
Milgram Neutral Newbie June 3, 2003 Author Share June 3, 2003 Okay, I think I get it now...if the weight of a 14" and 15" rim is about the same, then there is no difference to the weight pulling down the car (grip). However, because the tyres that come with the 15" is typically bigger than the 14", weight naturally goes up (rim + tyre). Add this to the larger contact between tyre and the road (due to a wider tyre width) and in totality, fuel consumption is very likely to suffer and goes up. Am I right? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 3, 2003 Share June 3, 2003 Yep...you finally got it but in return your braking and handling would become better.... Link to post Share on other sites More sharing options...
Milgram Neutral Newbie June 4, 2003 Author Share June 4, 2003 I got it because of the good brudders here in MCF . So would you recommend that I change my 14" to 15"? I saw that you advised another bro' here to stick to 14" if the car is 1.3 Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 4, 2003 Share June 4, 2003 If at 14" already feel under powered then don't change lah, unless the 15" rim is much lighter than the 14" .... Link to post Share on other sites More sharing options...
Milgram Neutral Newbie June 4, 2003 Author Share June 4, 2003 That's affirmative Boss! Thanks! Link to post Share on other sites More sharing options...
Saaber Neutral Newbie June 4, 2003 Share June 4, 2003 You're welcome... ↡ Advertisement Link to post Share on other sites More sharing options...
Advice on exhaust.
Advice on exhaust.
Car accident advice
Car accident advice
