Jeff49er Clutched April 6, 2009 Share April 6, 2009 My car is still happy with Shell Helix for last 12 years. Now it's on Shell Helix Ultra 5w/40. It's good enough to last for 10k OCI. As of today, my engine is still looks clean & there is no sign of consuming oil. This oil is good enough for passenger cars. I look forward to this oil when I do my 10k servicing at C n C. ↡ Advertisement Link to post Share on other sites More sharing options...
Freifeit Neutral Newbie April 6, 2009 Share April 6, 2009 (edited) Just to share.. one of my friend's volvo s60 2.0t was down due to sludge problem. He was using castrol edge but the actual culprit was PCV system clogged. The oil was contaminated by gas trapped inside the engine. Btw, PCV (Positive Crankcase Ventilation) is a system using a PCV valve to evacuate gases from an internal combustion engine's crankcase. Edited April 6, 2009 by Freifeit Link to post Share on other sites More sharing options...
Ahyoo2002 2nd Gear April 6, 2009 Share April 6, 2009 My car is still happy with Shell Helix for last 12 years. Now it's on Shell Helix Ultra 5w/40. It's good enough to last for 10k OCI. As of today, my engine is still looks clean & there is no sign of consuming oil. I am really curious, do current car still consume engine oil? For my previous car, which I have it for 7 years, I never top up engine oil at all. Link to post Share on other sites More sharing options...
Mercuri Neutral Newbie April 7, 2009 Share April 7, 2009 Just to share.. one of my friend's volvo s60 2.0t was down due to sludge problem. He was using castrol edge but the actual culprit was PCV system clogged. The oil was contaminated by gas trapped inside the engine. Btw, PCV (Positive Crankcase Ventilation) is a system using a PCV valve to evacuate gases from an internal combustion engine's crankcase. Just sharing with you guys here.... Oil that uses low SPAS(Sulphated Ash, Phosphorus, Sulphur) will reduce the chances of fouling your EGR which could clog your PCV. Low SAPS oil are those with ACEA C classification. Apparently, these low SAPS oil uses grp 3 oil. As far as i know, low SAPS oil do not use PAO and Ester formulated oil. It help you achieve better fuel consumption and reduce your emission as well as neutral to your Cat converter. So i prefer to get oil with ACEA C specs. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear April 7, 2009 Share April 7, 2009 my fc drop 2km/l on SHU i drain out after 500km Link to post Share on other sites More sharing options...
Espire 1st Gear April 7, 2009 Share April 7, 2009 If really that BAD....then i dont think so many Authorised Dealer Workshop using Shell Helix Ultra 5w40. And the current Shell is API SM. New Formula ACTIVE Cleaning Agents. Made In Singapore. oh so now it is made in singapore again... i remember some time back when i went to the shell petrol kiosk to check out the SHU origin.. it is from malaysia also... Link to post Share on other sites More sharing options...
Robo 2nd Gear April 7, 2009 Share April 7, 2009 my fc drop 2km/l on SHU i drain out after 500km your engine needs time to adjust to the new oil. u shouldnt drain so fast should have given at least 1.5-2k. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear April 7, 2009 Share April 7, 2009 rough Link to post Share on other sites More sharing options...
Strobe Neutral Newbie April 9, 2009 Share April 9, 2009 I just change it to SHU on my recent oil change... so far so gd... still monitoring... Link to post Share on other sites More sharing options...
Karie Neutral Newbie April 10, 2009 Share April 10, 2009 your engine needs time to adjust to the new oil. u shouldnt drain so fast should have given at least 1.5-2k. Bro he is a fan of Castrol la ↡ Advertisement Link to post Share on other sites More sharing options...
Xiaomi 13 Ultra
Xiaomi 13 Ultra
yuu Rewards Club app
Pennzoil Ultra Platinum Engine Oil
upgrading the DSP make any difference?
NTUC selling 4L Shell helix ultra at $59
Shell Helix Ultra
Shell Helix Ultra
Now Giant's turn to offer Mobil 1 engine oil!
